Replace Cooling System Expansion Tank
Old Apr 13, 2022 | 02:59 PM
max224's Avatar
Default Replace Cooling System Expansion Tank
Okay, I know this has been covered in the past and there is even a post with step-by-step photos but, for some reason, the pictures no longer accompany the narrative, The tank in question is in a 2002 pre-facelift S-Type with the 4.0 engine. I need to disconnect the hose from the cooling tank to the heater core to remove the old tank. The new tank comes with the hose attached, so I could hopefully break the clamp, slide off the old hose and slide on the new one (I have the right hose clamp pliers, but the clamp is in the wrong position).
. I just need to confirm that I'm looking at the correct hose (see above).
Thanks for your help.
Old Apr 13, 2022 | 06:18 PM
kr98664's Avatar
Originally Posted by max224
I need to disconnect the hose from the cooling tank...
Is access any better at the far end of the hose? If so, disconnect that end and remove the tank and hose together as a unit. Then you can tackle that pesky clamp from the comfort of your work bench. Same goes for installation.
Old Apr 13, 2022 | 08:35 PM
motorcarman's Avatar
Take the hose off the pipe and leave it on the plastic tank.
Old Apr 14, 2022 | 06:35 AM
S-Type Owner's Avatar
I think I would replace the hose along with the tank. It looks like it may be original to the car and a little extra money spent now is preferable to a costly break down at a later date...
Old Apr 15, 2022 | 12:19 PM
max224's Avatar
Thanks for all of your replies and suggestions. I'm a bit under the weather today, but will see if I can remove the clamp which is somehow not angled to where I can use my hose clamp pliers. I'll probably break if off, slit the hose and get the reservoir out. As has been pointed out, the replacement has the hose attached. Then all I have to do is drill out and remove the three bolts I broke to move the cross-brace and put it all back together! The fun never ends....
Thanks again for everyone's help. .
Old Apr 16, 2022 | 08:50 AM
Old Apr 16, 2022 | 01:28 PM
max224's Avatar
Thanks motorcarman! I remember seeing that exact tool years ago, but unfortunately didn't buy it that time. I'm going to look for it online; one of those tools that you don't need until you do; should pay for itself in time saved in one use.
Old Apr 16, 2022 | 07:44 PM
scottjh9's Avatar
I got one similar at autozone if they are close. Absolute knuckle saver
Andy W Nichols
Aug 22, 2020 12:15 PM
Open
Feb 3, 2020 06:25 PM
n8ertot
Oct 26, 2015 01:18 PM
chrisc923
May 20, 2014 02:02 AM
Lannyl81
Feb 10, 2013 08:59 AM
