Replacing door fascia panels
Old Jun 23, 2016 | 11:19 AM
Staatsof's Avatar
Default Replacing door fascia panels
I've done the dash panels and I know how those work. Looking at the replacement door panels I had I thought that these would be similar but that appears to not be the case.
I was able to remove them carefully with a pair of plastic pry bars.
However, when I tried to push the new ones in they do not seat tightly and completely. The door panels do flex/move quite a bit.
Any tips out there? Do I have to remove the entire door panel?
Are there clips that attach from the backside that can only be seated properly with the panel off of the door?
Thanks.
Old Jun 23, 2016 | 01:53 PM
Datsports's Avatar
There are little pressed metal nuts holding all the parts together from behind the door pannal , I'm suprised you could prise them off ! You may have broken the plastic pins that the nuts screw on to .
Old Jun 23, 2016 | 02:03 PM
Staatsof's Avatar
Hope not!
On the dash pieces sometimes the retaining clips pit out and sometimes the panel tabs just pull out. There is no other way. Perhaps stupidly I thought these were very similar in nature.
So perhaps those press on nuts/clips have simply fallen out of the backside?
Trying to get my JTIS to work in Win 7 again but no luck so far ...
Perhaps that will shed some light?
Uncle Fishbits
Oct 31, 2019 11:08 AM
Jandreu
Apr 14, 2016 02:32 PM
wa3ra
Apr 12, 2016 07:40 PM
joejag05
Apr 4, 2016 09:17 PM
razorboy
Mar 29, 2016 01:08 PM
