Reverse Parking Aid Volume?
Old Nov 15, 2022 | 11:34 AM
kr98664's Avatar
Default Reverse Parking Aid Volume?
Boys and Girls,
On my '02, the volume is very low on the reverse parking aid. The beeping action seems to work fine. The only problem is the volume is low. Anybody run into this before? I remember it used to be a lot louder, but I don't recall when it changed.
Looking at the wiring diagram, the parking aid system has a dedicated speaker. I was wondering if the output used the stereo speakers, but that doesn't appear to be the case.
Old Nov 15, 2022 | 12:09 PM
I think the speaker is under the rear parcel shelf from memory, I wonder if it could have fallen off?
Or maybe it's suffering from old age, I know how that feels.
I've attached the retrofit instructions in case that helps.
Old Nov 15, 2022 | 01:07 PM
kr98664's Avatar
Ooh, hadn't considered that. Post #4 here shows the location, just forward of the center brake light. I'll have to take a look when I get a little free time:
https://www.jaguarforums.com/forum/s...s-type-207036/
Old Nov 15, 2022 | 02:07 PM
clubairth1's Avatar
Community Influencer
Maybe just adjust the loudness?
It can only be adjusted when it's on so get the sensors beeping and you should be able to turn the volume knob and increase the volume.
Old Nov 15, 2022 | 02:21 PM
kr98664's Avatar
Which volume knob? On the stereo?
Old Nov 15, 2022 | 02:59 PM
That's not much of a challenge! Fingers crossed for you Karl.
Old Nov 15, 2022 | 03:48 PM
kr98664's Avatar
No joy. With the beeper sounding faintly, I played with the stereo volume, audio system on and off. Any prerequisites?
Old Nov 15, 2022 | 07:53 PM
I've never heard of it being adjustable on the S Type, but it would have been nice.
Old Nov 15, 2022 | 09:49 PM
Scotlad's Avatar
Maybe hook it up to a 12" woofer, you should be able to hear that!
Old Nov 16, 2022 | 08:24 AM
clubairth1's Avatar
They must have changed it because the stereo volume knob on my 2005 STR did adjust the parking sensor volume when they were making noise.
Same thing on my 2014 XJ?
Old Nov 16, 2022 | 08:54 AM
kr98664's Avatar
Maybe only on the later models? Mine is a 2002.
Old Nov 22, 2022 | 08:53 AM
kr98664's Avatar
Picked up a used speaker on eBay. Might be a little while before I get to install it. Will update then.
Old Jan 31, 2023 | 09:25 AM
kr98664's Avatar
Two months and several crises later, I finally had a little free time to replace the speaker. It works great, but oy vey, what a pain! Access wasn't so bad, but the foolish thing was secured with pop rivets. I had to drill them out from underneath.
For access, fold down the two rear seatbacks. The reverse speaker is located on top of the metal structure under the rear window, below the fuzzy trim panel (aka parcel shelf). It's located just forward of the center brake light, a little bit offset towards the US driver's side. You don't have to remove the trim panel completely, and need only lift up the front. Remove the three car seat anchors across the top and the three large trim clips, normally hidden by the seatbacks:
Gently lift up the trim panel and position a spacer to hold it up a few inches. I used a roll of tape, but anything similar will work:
Here's a close-up of the speaker. Access is tight like this, but not too bad:
With the trim panel lifted up, you can plug in your new speaker for testing. No point in removing the old speaker if the problem is elsewhere.
Here's a view of the speaker after removal, showing the location of the two fasteners and electrical connector. Look closely and you'll see the remains of one of the blasted pop rivets. Maybe you'll get lucky and something other than rivets were used:
If were to do it all over again, and had to deal with the pop rivets, I would simply secure the new speaker with double-sided tape, close to the old speaker. Swap over the connector and there would be no need to remove the old one. There's plenty of room. Hindsight is always 20/20, isn't it? But of course I did it the hard way.
There is little room to drill out the rivets from above. You might get in there with a compact 90 drill, but don't hold your breath. Access from underneath is blocked by a big plastic housing for the audio system speakers. Not sure about all models, but my car has the premium factory sound system and a large enclosure for the speakers. This image, shamelessly stolen from eBay, shows the 5 fasteners (circled in red) and the electrical connector that must be removed to drop this enclosure. This unit is fairly heavy and awkward to handle, so a helper is suggested. This view is from underneath, looking up if installed:
With the speaker enclosure out of the way, this view shows the location of the two offending rivets, already drilled out in this image. This view is from the floor of the trunk, looking up and forward:
No way was I going to rivet the new speaker in place. I used double-side tape, but you could use any sort of fastener your little heart desires. Once again, in hindsight, there's no need to remove the old speaker if riveted. If you decide to drill out the rivets, they might spin. Secure them with a drop of super glue to make the process easier. I would also suggest laying down a sheet of plastic or similar to catch any metal shavings, to make clean-up easier.
With the job completed and everything put back together, I'm cleaning the trunk with my cordless vacuum. How well does it work? This vacuum really sucks.
For a replacement, here's the number (98AB-15K864-AA) on the back of the speaker. You can use that or the official Jaguar part number (XR88580) when searching:
I've noticed similar speakers available for Ford vehicles of this era. Most likely one would work just fine but I am not positive.
Old Feb 7, 2023 | 03:20 AM
LLLA's Avatar
Damn, I didn’t see this earlier, my bad. I have 3 of these I’ve pulled from the yard, I would have sent you one! (I got to cheat because people before me had pulled the rear glass off)
That is also where the GPS antenna is mounted if you have the navigation package.
Great write up. Yes, you are correct. FoMoCo used those speakers across all their models with backup sensors of the time. Part numbers are different (of course).
If you (or anyone) needs parts like this, please feel free to ping me. There are at least 10 LKQ locations near me and they have a steady flow of S-Types coming in weekly. I typically go on weekends to practice techniques to avoid breaking my own stuff….or just tear through cars for fun.
kb58
Jun 14, 2022 09:25 AM
jlewis10
May 4, 2021 10:31 PM
KentInCalgary
May 29, 2020 04:26 PM
aibeekay
Aug 23, 2009 07:44 AM
mjbedingfield
Aug 4, 2008 06:09 PM
