Rough running
Old Jan 21, 2013 | 09:57 AM
wawaman's Avatar
Default Rough running
Hello everyone,
My 2000 s type with 90,000 miles on the clock runs very rough. The most baffling thing is that there are no DTCs showing up. The problem seems to be only with the Left Hand Bank of the engine. I have changed the plugs, coils and checked if there are any air leaks; there seems to be non. I have tried to see if it is a cold weather thing, but it isn't. It starts of in the mornings idling as rough as ever, progressively getting worse as the engine warms. Driving, as soon as she selects the 5th gear the car starts shaking giving a rough drive.
Help please!
Old Jan 21, 2013 | 10:15 AM
Welcome to the forum wawaman,
(I've moved your tech question from Jaguar Forums Advice / Feedback & Suggestion Centre section to S-Type section.)
When you get a minute, please follow this link https://www.jaguarforums.com/forum/n...-intro-must-5/ to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Jan 21, 2013 | 11:01 AM
JagV8's Avatar
Engine? See:
Old Jan 21, 2013 | 03:12 PM
tbird6's Avatar
We need a lot more to help!
Have the tensioners been changed? If not stop right here!
Old Jan 21, 2013 | 08:25 PM
abonano's Avatar
+1 on tensioners - if tensioners were changed out then check all of the fuel injector electrical connections. (ensure they are tight and secured to the injector) - to add, who changed the coils? Were the coils only changed on the left side of the engine or all?
As pointed out - more detailed information is required.
Old Jan 21, 2013 | 10:52 PM
wawaman's Avatar
Thank you all.
Car is 2000 s type with 90,000 miles.
The coils and plugs were changed for the Left bank. Removed the intake manifold and checked all the injectors and their connections; all are tight.
Old Jan 22, 2013 | 01:59 AM
JagV8's Avatar
A 3.0 ... not tensioners, they're the 4.0
It'll be a hose causing an air leak, try Search on
elbow
hose
air leak
All the details with part #s in there.
Old Jan 22, 2013 | 02:30 AM
wawaman's Avatar
Thank you Jag V8.
Its not an air leak.
The problem is only with Left Bank. With the engine running going behind to the exhaust, only the Right Bank is giving out hot fumes. The Left bank is barely showing signs of life. The Right bank exhaust outlet is dark gray/black while the Left bank is brown.
Old Jan 22, 2013 | 05:32 AM
JagV8's Avatar
Blocked cat, bad O2 sensor, could still be an air leak. Do more diagnosis.
Maybe remove upstream O2 and use borescope & check gases.
Old Jan 22, 2013 | 09:23 AM
abonano's Avatar
Did you use OEM coils or aftermarket for replacements? Many will tell you - aftermarket coils are not the greatest...
Bcrary3
Feb 21, 2023 04:29 AM
trosty
26
Dec 18, 2022 06:40 PM
kevo
Sep 8, 2015 09:45 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
Bowman
Sep 3, 2015 03:17 PM
