S-Type 2003 3.0 Big Question RESOLVED
Old Jan 21, 2019 | 11:47 AM
  #41
Idle and 2500rpm long term and short.
Old Jan 21, 2019 | 11:57 AM
  #42
trycons's Avatar
Here are photoa from my obd on idle
Old Jan 21, 2019 | 12:00 PM
  #43
trycons's Avatar
2.5k rpm
Old Jan 21, 2019 | 12:43 PM
  #44
JagV8's Avatar
Looks like not properly warmed up but probably no air leak.
So on to the other thing asked: OBD monitors.
Nothing at all to suggest problem with throttle!
Old Jan 21, 2019 | 02:33 PM
  #45
trycons's Avatar
Im giving up , jag still have no power to accelerate . 140-150km/h and thats all. No idea what i should check next..
Old Jan 21, 2019 | 02:45 PM
  #46
What about the monitors, which ones are set and which are not?
Old Jan 21, 2019 | 03:46 PM
  #47
JagV8's Avatar
I keep asking ...
Can't help some people
Old Jan 22, 2019 | 03:33 AM
  #48
trycons's Avatar
its that?
Old Jan 22, 2019 | 04:21 AM
  #49
JagV8's Avatar
At some time you must have cleared the codes - but haven't managed to fix all their causes.
You can get Catch-22 that way, where it can no loger flag codes because it can't set the monitors and can't set the monitors because it has something(s) wrong but isn't sure what.
Did you change the cat. conv to fix the P0430?
Your trims may well mean there's an exhaust-related or EVAP-related issue.
Old Jan 22, 2019 | 08:13 AM
  #50
trycons's Avatar
I didnt change Cat. I can replace it to orginal or i can buy Universal Cat?
Old Jan 22, 2019 | 02:24 PM
  #51
trycons's Avatar
@JagV8 @Norri
I got another question, i searching for way to get a WDS/SDD how many it cost? Can u link me a device which i can connect my jag -> mongoose will work? or something else, i think without a good comp i will do nothing
Old Jan 22, 2019 | 02:53 PM
  #52
JagV8's Avatar
IDS/SDD & WDS are not easy to use - you would normally be an experienced mechanic and go on a training course - and not especially cheap.
You can use them to wreck your cars computers. If you get either tool do not program anything!!
You look to be having trouble with quite simple tools so this looks an unwise direction.
Old Jan 22, 2019 | 03:16 PM
  #53
I'd agree, there is a fair bit of risk using the dealer tools without being familiar with the procedures.
Old Jan 22, 2019 | 03:25 PM
  #54
trycons's Avatar
I got the mechanic who can use it, but he didnt got the computer to work, we are searching for tools..
Old Jan 22, 2019 | 06:13 PM
  #55
JagV8's Avatar
So far you don't seem to have any problems needing them.
But they're good if you're careful and spend plenty of time.
Old Jan 24, 2019 | 11:14 AM
  #56
trycons's Avatar
I got new DTC codes, im really giving up with this car. please help . there is p0300, 302, 304, 306, and 1314 codes.
Old Jan 26, 2019 | 07:50 AM
  #57
JagV8's Avatar
Others have had them - read what has been said about them in the past and the things to do next.
Old Jan 26, 2019 | 11:04 AM
  #58
Don B's Avatar
Hi trycons,
First of all, please use your User Control Panel to add the year, model and engine information of your Jaguar to your signature line so others won't have to guess. I had to go to your public profile to learn that you have a 2003 S-Type 3.0L.
Secondly, download the document at the link below, which has definitions of the Diagnostic Trouble Codes (DTCs), including your misfire codes, plus lists of possible causes for each code that will help you and your mechanic diagnose the problems. Start with the possible causes of P0300.
Jaguar S-Type DTC Summaries 2003
The fact that all of your misfires are in Bank 2 suggests a problem that affects only that side of the engine. A couple of easy tests would be to pull the ignition coil on cylinder 2 and check for oil in the spark plug well from a leaking plug tube seal. If you see oil, replace the cam cover gasket, spark plug tube seals and spark plugs. Note that the Jaguar 3.0L V6 engine is an upgraded version of the excellent Ford/Mazda Duratec (initially designed by Porsche and Cosworth), and the correct spark plugs are Ford Autolite, not NGK as used in the Jaguar V8s
If no oil is evident, check the supply voltage to the ignition coils and fuel injectors on cylinders 2, 4 and 6. You can download the Electrical Guide here:
Jaguar S-Type Electrical Guide 2003
Here's the diagram that shows the cylinder numbering on your engine (the arrow indicates the front of the engine):
Cheers,
Don
Old Mar 14, 2019 | 02:04 PM
  #59
trycons's Avatar
The reason was Catalyst conventer on both sides
Old Mar 14, 2019 | 09:40 PM
  #60
Don B's Avatar
Hi trycons,
Thanks for reporting back!
You only had misfires on Bank 2... Was the cat on that side clogged up? Why did the Bank 1 cat have to be replaced?
Cheers,
Don
