S-type 3.0 V6 Brakes
Old Oct 11, 2012 | 06:06 PM
rvseverson's Avatar
Default S-type 3.0 V6 Brakes
How much work is it to change my 2008 S-Type V6, 300mm rear rotors to the 326mm? I did try searching but came up empty. Thanks
Old Oct 11, 2012 | 06:17 PM
joycesjag's Avatar
rv, welcome to the forum. Might I suggest that you follow forum protocol and go to the "New Member Area" found here: New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and introduce yourself. This will bring you up to full membership and has more benefits.
I do not recall anyone here over the years wanting to switch over the rear brakes to the 326mm on a V6 S Type. You may have some possibilities on searching out on the 4.2 versions instead. Also as I recall you need larger wheels to accommodate the 326mm.
As I remember as well the few who did post a similar questions gave up their quest due to the amount of work and money.
Good luck on your venture and if you proceed please take the time to post up pictures.
Thank you
Old Oct 12, 2012 | 04:03 AM
JagV8's Avatar
Kinda puzzled as to why you'd want to...
Old Oct 12, 2012 | 05:15 AM
joycesjag's Avatar
So am I, but I did not want to be nosey.
Old Oct 12, 2012 | 12:59 PM
Jochem00's Avatar
About an hour including flushing the oil
Old Oct 12, 2012 | 01:35 PM
JagV8's Avatar
Er... what?
Old Oct 12, 2012 | 04:36 PM
Jochem00's Avatar
1 hour to remove calipers take old discs off put new discs on put new pads and calipers on and bleed the brakefluid
Old Oct 12, 2012 | 04:49 PM
Won't the caliper mounts have to change also?
Jefro
Sep 15, 2015 01:44 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
wwac
Sep 1, 2015 05:45 AM
NinoGrimace
Aug 26, 2015 05:15 AM
