s type 4ltr auto trans
Old Aug 14, 2012 | 06:57 AM
rolyjm's Avatar
Exclamation s type 4ltr auto trans
my auto gear lever will pull back to D but no drive
if i move to 4 and push hard forward (lever only just moves a few mm) then
get drive
have gone through all the fourms about adjusting shifter and got that right,
But cannot gear lever to go past 4 ( to 3 or 2) ie move gear lever forward
cheer roly
bunbury western australia
Old Aug 14, 2012 | 07:39 AM
abonano's Avatar
Your shifter cable could be streteched to the point that would render adjusting useless. (you did properly adjust the cable from R-N and N-d - yes?) Could also be the shifter assembly itself.
Old Aug 15, 2012 | 03:31 AM
rolyjm's Avatar
Default S type auto
Yes I did adjust it that way
What goes wrong in the shifter is electrical ie
Are there any sensors there
As I have checked the micro switch for D . 4
The solenoid works ok for locking lever
But dont know if there is any thing in the top black display
Other then the position lights (any sensors)
Thanks roly
Old Aug 15, 2012 | 06:07 PM
motorcarman's Avatar
You need to read TSB S307-06. I uploaded it several years ago and it should be in the stickey section.
I could upload it here but you won't be able to download until you get 10 posts.
bob gauff
Old Aug 16, 2012 | 08:09 AM
rolyjm's Avatar
Default S type auto
Tsb s307-06
I did find it (googled) is this about cable inner moving etc
Thanks for your help
Old Sep 4, 2012 | 04:47 AM
Roly's Avatar
Default shifter
Just changed the Shifter S/Hand . before I installed it i replaced the white plastic part with the aluminum mod one. but still the same
also i cannot see any inner sleeve movement . so now its buy a new cable and try that, Or is there something in auto box that can stop lever moving from 4 to 2
thank you roly
Old Sep 14, 2012 | 04:29 AM
Roly's Avatar
Default New cable
Well. After getting a shifter and fitting
Still the same
I sent for for cable from road bends. (Perth western Australia)
Fitted and all ok
Thank you all for info
Roly
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
