s type engine swap
Old Dec 31, 2012 | 07:33 PM
htes311's Avatar
Default s type engine swap
hello everyone i have a 2000 s type with the 4.0, bought it with bad headgaskets and when we tore it apart some valves were broken lone story short i bought a engine from a 01 but when i bolt the trans to the motor it wont turn over it locks up when i pull the motor out i can turn it over just fine, i am almost positive the converter is in all of the way, does a 01 have a differnt flex plate? have put the motor in and out 6 times now and help would be great thanksss
Old Dec 31, 2012 | 09:26 PM
bfsgross's Avatar
Recently (two weeks ago) there was an almost identical question as yours from a chap doing the exact swap. Check the "Search Forum Feature" for how he tackled this. If memory serves me correctly, the torque converter wasn't sat far enough on the shaft or whatever?
Old Jan 1, 2013 | 11:24 AM
abonano's Avatar
+1 on bfsgross recommendation - also, I need to let you know - you should have opted to get a 00 - 4.0 engine as I have seen many auto wreckers (and ebay) notate 4.0 engines from 2000 through 2001 as follows:
This part will fit these makes and models with these options
S TYPE 00 4.0L, (VIN D, 8th digit)
S TYPE 01 4.0L, thru VIN L86901 (VIN D, 8th digit)
Hopefully the 01 engine you purchased is before VIN L86901 or this could be a source of concern moving forward.
Just my $0.02
Old Jan 2, 2013 | 11:23 PM
htes311's Avatar
thanks guys but im not very good with this site yet i tried finding the post with no luck, does anyone have a link or a title to search, thanks again
Old Jan 2, 2013 | 11:44 PM
htes311's Avatar
from what i can find the flex plate is different on some of the 01s but i cant find anything that says if the torque convertor is different?
Old Jan 3, 2013 | 12:26 AM
Here is the thread the guys were talking about https://www.jaguarforums.com/forum/s...-s-type-86660/
Old Jan 3, 2013 | 07:27 AM
bfsgross's Avatar
Sent a PM to neil to see if he finished his engine swap. He last mentioned a weeks worth of rain.
Old Jan 3, 2013 | 12:35 PM
htes311's Avatar
thanks for the help i did notice his is a 3.0 and mine is a 4.0
stanjag
Dec 29, 2024 08:26 PM
Mr. Mohr
Nov 27, 2015 08:55 AM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
