S type fuse diagram
Old Jul 11, 2009 | 05:24 PM
Thermo's Avatar
Veteran: Navy
james, check fuse #20 (10 amp) in the primary fuse box and also fuse #29 (5 amp) in the primary fuse box. Both of these feed power to the wipers. You will also need to check fuse #8 (10 amp) in the rear distribution box. The cover should show you where each of these fuses are based on number. If you need more help, I will give you a detailed location of where each of these fuses are located.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
jehart49
Sep 12, 2015 05:36 PM
dcvickers
Sep 2, 2015 06:14 PM
TC Johnson
Sep 2, 2015 09:30 AM
