S Type Ignition Coil Pack
Old Dec 14, 2017 | 11:29 AM
dtmob48's Avatar
Default S Type Ignition Coil Pack
All,
I have a 2005 Jaguar S-Type R and I am about due to change my spark plugs. According to the previous owner's service history the spark plugs and ignition coils are original. Should I go ahead and replace my ignition coils with the spark plugs? If so, what are the most reliable, best bang for your buck ignition coils?
Autozone sells a direct fit at 49.99 a piece (Duralast), but sells the multi-pack (8 coils) for 200 bucks. This is by far the best deal I have found, Delphi runs about 53 per coil and I found the Factory Jag Coils for 75 per. I searched the S-Type forum but haven't found much regarding the best brand/price ignition coil or when to change them other than when they have already failed.
Hope somebody can help. Thank you!
Old Dec 14, 2017 | 11:53 AM
JagV8's Avatar
As they cost so much and are not (I hope!) throwing codes I would keep the coils.
Buy one good spare by all means.
Plugs are NGK IFR5N10 and are both pre-gapped (if you check, treat the central electrode VERY gently) and have an anti-seize coating.
Take plugs out with pretty hot engine or they may be very tight.
Old Dec 14, 2017 | 02:15 PM
dtmob48's Avatar
No codes have been thrown! I'm getting up there in miles so I figured I would ask the Forum if it would be worth it or not while I'm "under the hood." I might buy a spare factory replacement just in case and then replace them as they go. Seems more economical LOL.
Thank you for the advice and plug replacement tips!
Old Dec 14, 2017 | 03:22 PM
Robman25's Avatar
Remember if you are working on a hot engine that if you tighten the spark plugs hard down in the hot head they might be real unhappy to come out next time.
Old Dec 14, 2017 | 05:29 PM
JagV8's Avatar
Good point although by the time you get them all out (if you don't put the new ones straight in) it'll have cooled down quite a bit.
Cambo
Sep 19, 2017 04:47 PM
macudc
Feb 10, 2015 09:53 PM
edgejag
23
Dec 8, 2014 02:40 PM
barmorehome
Sep 5, 2014 09:45 AM
gvpierce
Apr 24, 2013 08:20 PM
