S Type Rear clonk
Old May 26, 2014 | 03:01 PM
paullap's Avatar
Default S Type Rear clonk
Hi I have a 2007 2.7 diesel auto, when slowing down to make a turn, just before I come to a stand still, I get a clonk from the rear of my car. I think it is the left hand side, but it is difficult to tell, anyone have any idear's.
Paul
Old May 26, 2014 | 04:40 PM
GT42R's Avatar
Likely stabilizer-bar end-links,
Otherwise, lower strut mount bushings, and some of the lower control arm bushings are known to wear.
Old May 26, 2014 | 06:17 PM
clubairth1's Avatar
Community Influencer
Are you sure it's not a bit of the "lurch"?
I get it coming to a stop once in a while and it really can clonk the rear end!
Old May 26, 2014 | 11:22 PM
paullap's Avatar
It realy feels like something is coming forward as i slow down, but it does not happen at higher speeds.
Paul
Old May 27, 2014 | 02:07 AM
JagV8's Avatar
I was going to suggest rear ARB (sway bar) bush as it can cause a clonk noise but I don't think you'd feel it like that.
Old May 27, 2014 | 02:44 PM
paullap's Avatar
It is defanatly coming fron the near side rear.
Old May 27, 2014 | 02:46 PM
JagV8's Avatar
Park. Bounce car rear hard each side. Jack up, shake wheels, spin wheels, remove, hunt for any damaged bushes etc. Pry on metal arms. Any mechanic can do it...
Old May 27, 2014 | 02:50 PM
paullap's Avatar
Thanks I will see what I can find.
Paul
Old May 31, 2014 | 09:16 AM
paullap's Avatar
Default Found the clonk
It is the rear diff mounts, 2 off them, I am trying ti attach a picture, Has anyone changed these before 2007 s type.
Paul
Old May 31, 2014 | 09:23 AM
Mikey's Avatar
I see nothing wrong. What do you see?
Old May 31, 2014 | 12:25 PM
clubairth1's Avatar
Maybe get another opinion?
Because those don't go bad hardly ever and like Mikey said they all look that way?
Old May 31, 2014 | 01:28 PM
paullap's Avatar
Default clonk
I put the car over my pit, I then got my wife to hold the brake, put it into gear forward and then reverse ,and I can then feel the clonk on these bushes. I need to know how dificult it is to change them.
Paul
Old Jun 6, 2014 | 12:12 AM
paullap's Avatar
Default What are these bushes called
Does anyone have a part number or what these bushes are called? s type
2007 2.7 diesel, I am going to replace them and see if it cures the problem.
Paul
Old Jun 6, 2014 | 01:11 AM
JagV8's Avatar
Call a dealer. Or maybe an online place will show them.
Old Jun 6, 2014 | 12:26 PM
tbird6's Avatar
Well I still don't think that is your problem.
When you have replaced the bushings please report back with what you found.
You will feel that clonk anywhere you put your hands because it's all tied together.
Old Jun 6, 2014 | 04:20 PM
paullap's Avatar
Default clonk
I am going to have a better look tomorrow. I think you might be right but it really did feel like those bushes. I will keep you posted.
Paul
Old Jun 6, 2014 | 05:16 PM
tbird6's Avatar
I am only arguing because we just have not had anybody I can find that needed to replace these.
So either they don't wear out/fail very often or we just don't notice it.
Jaguar actually has some metal spacers that can be inserted in the slots of the bushing. This was for a clunk noise problem. I ordered a set and put them in but still have a small clunk when taking off. It's been there since I got the car at 32K miles and I am now at 103K miles.
However I noticed your car does not have these slots in the rubber bushings so that must be one of the running changes Jaguar did on the newer S Types. Maybe this was an attempt to reduce bushing movement?
Interested to see what you find.
Brutal have you got any input on this?
Old Jun 14, 2014 | 01:52 PM
paullap's Avatar
Default Had another look
I got back under the car today, It is most certainly these 2 bushes, With afoot on the brake and going into forward and then reverse, These 2 bushes moveup and down about a 1/4" of an inch without the rubber moving, and thediff is turning back and forwards, the car has a tow bar, so if the previousowner did a lot of towing, like a caravan, I wonder if this is the cause?. I amfitting a new ramp in my garage at the moment, as soon as it is done, this will be my firstjob.
Paul
Old Jun 25, 2014 | 11:20 PM
paullap's Avatar
Default a bit of advise wanted o this clonk
Had another look at these bushes today, I can see that they don’t look wornBut I can see them moving up and down when going from drive to reverse with thefoot brake on, and can feel the clonk when touching them, but I am thinkingthat it could be travelling from some where else, to replace these bushes itlooks like the sub frame has to be removed, so I am thinking about replacingany other bushes on the rear end that are a common problem before I tackle thesub frame removal, the car has done about 75000 miles and a tow bar fitted bythe previous owner. I might even go and see a Jaguar specialist to get somehelp. Anyone have any suggestions.
Paul
Old Jun 26, 2014 | 01:53 AM
JagV8's Avatar
Statement of the obvious: all suspension bushes & joints are wear items and need replacing at some point. Do the ones that are loose/cheap/etc to your own taste (or MoT).
