S Type Rear clonk
Old Jul 20, 2014 | 05:11 AM
paullap's Avatar
Default rear clonk
I know this is for an earlier S type, but this very simular to the problem I am having.
http://www.jagrepair.com/images/TSB/...%20Vehicle.pdf
Paul
Old Jul 21, 2014 | 07:04 AM
clubairth1's Avatar
Community Influencer
Yes I have installed those on my 2005 STR for a small clunk. It did not fix it.
Old Jul 21, 2014 | 03:19 PM
paullap's Avatar
Default clonk
Do you still have the clonk?, it is driving me bonkers, I have to fix it, I just want to get as much information as I can before i start to strip the rear end down to find the problem.
Paul
Old Jul 21, 2014 | 05:17 PM
tbird6's Avatar
Yes. It's a fairly small noise and I only get it when taking off at a pretty good rate. I can drive around it easily but it's been there since I got the car 5+ years ago. I am now at 104K miles and it still the same as it was at 33K miles.
Not a big deal but I have read a few other people having this issue.
Old Nov 8, 2014 | 12:11 AM
paullap's Avatar
Default clonk fixed
Hi, I have finally got to the bottom of the problem, I took the car to XJengineeringin Bentley, I was so fed up with the clonk I decided to go to aspecialist, he found that the Diff mounting bolts had been changed, for whatreason we don’t know, anyway the bolts where to long and bottoming out, so hetook them out cut some off re dressed the thread and bolted them up tight, allfixed and no clonk, excellent job.
Paul
Old Nov 8, 2014 | 01:18 AM
JagV8's Avatar
Interesting. Some of the later cars had diff problems and the diff was replaced but with a different make. Sounds like they used the wrong bolts (maybe reused the old ones).
Old Nov 8, 2014 | 04:03 PM
clubairth1's Avatar
Are those the same bolts in your picture?
I may take them out one at a time and inspect.
Old Nov 9, 2014 | 02:43 AM
  #28
Timmyboy's Avatar
I've just had a 2nd hand diff fitted to mine and ended up with this clonk - fixed by using a couple of small shims to fill the space for each bolt. As suggested, there must be a subtle difference in diff design over the years.
Old Nov 9, 2014 | 02:47 AM
Timmyboy's Avatar
Note though - if Jaguar fit a replacement diff (under warranty for example) it will be an XF unit including replacement driveshafts etc. My replacement was from a S-type though, being 2nd hand.
Old Nov 9, 2014 | 09:09 AM
  #30
clubairth1's Avatar
It looks like maybe Jaguar changed those bushings and removed the openings on all four sides and made the bushing solid?
I installed these inserts.
I have attached the TSB talking about them too.
File Type: pdf
Old Nov 9, 2014 | 01:53 PM
  #31
slauson slim's Avatar
My 2008 S Type 3.0 had a rear end clunk slowing down and accelerating, and my tech diagnosed the same problem, and did the same repair, as to paullap's car. No more clunks.
Old Nov 12, 2014 | 11:09 AM
  #32
Jimmy 68's Avatar
I'm betting its still the sway bar end links. Common issue.
According to the noise symptoms you've described, I have a similar noise, I believe my front ones are bad too.
Had same exact noise on my wife's '05 Ford Escape ( Maverick). Problem was sway bar end links.
Old Nov 12, 2014 | 11:14 AM
  #33
Jimmy 68's Avatar
Disregard...
Old Nov 13, 2014 | 12:01 AM
  #34
hilaryv215's Avatar
I just wanna say I recently spend $1450 having my sway bar bushings replaced. My car wasnclonking AND I FELT IT.
Good luck
Old Nov 13, 2014 | 03:52 PM
  #35
tbird6's Avatar
Front or rear sway bar bushings?
Old Nov 13, 2014 | 08:12 PM
  #36
Wuzupez's Avatar
You spent that much on sway bar bushings? There must of been something more? That's unheard of....
Old Nov 14, 2014 | 06:43 PM
  #37
ONEsicJAG's Avatar
^^^That's What I Said...
Old Nov 15, 2014 | 08:41 AM
  #38
hilaryv215's Avatar
Well the labor they said was $650 than parts.
It was my front but my back is clicking now....
And be quiet ONESICJAG if I would've had the help someone offered I wouldn't be $1400 in lol
Old Nov 15, 2014 | 08:42 AM
  #39
hilaryv215's Avatar
Oh I'm sorry minute $150 of that for my steering belt thing....
stanjag
Dec 29, 2024 08:26 PM
frujag
Sep 1, 2015 03:43 PM
ogorir
US Southwest
Sep 1, 2015 10:05 AM
martybmw
Aug 31, 2015 10:15 PM
dpappyp
Aug 27, 2015 06:31 AM
