S- type serpentine belt
Old Feb 3, 2016 | 07:48 AM
NikolaiDiqnov's Avatar
Default S- type serpentine belt
Can someone provide me with the correct dimensions for the serpentine belt for Jaguar S type, V6 petrol, model year 2006. Here, in my home country, there is a shortage of Jaguar parts and I cant find an original one. Is there some alternative to the original? Thanks in advance.
Old Feb 3, 2016 | 08:28 AM
Gus's Avatar
Gus
Do you have an auto parts store in your area? If I recall the part number is the same as a Lincoln LS V6
Old Feb 3, 2016 | 01:29 PM
The problem is that here, in Eastern Europe, Lincoln is not exactly a popular brand also.I was wondering if the S type serpentine belt could be replaced by some Ford part?
Old Feb 3, 2016 | 01:46 PM
Jon89's Avatar
Go to some of the online aftermarket parts sellers (rockauto.com is one example) and search for serpentine belts for your particular vehicle. I'm sure there are European online aftermarket parts sellers as well. You just need to confirm what particular belts are an exact-fit for your vehicle....
Old Feb 3, 2016 | 04:19 PM
tbird6's Avatar
You do know that Ford makes Lincoln right?
So the Lincoln part is a Ford part.
Old Feb 3, 2016 | 04:56 PM
Here ya go.
Dayco part # 6PK2730.
Gates and Bosch use the same number.
It is an "industry standard" part numbering system, so any half decent Auto Parts Mob should be able to supply IT, or convert it to their numbers.
Dayco - power transmission and cooling system components
Old Feb 3, 2016 | 05:13 PM
Six Rotors's Avatar
So it is 2730mm effective length(107.5 inches),and 6 ribs (0.84inches wide--measured across the flat).
Old Feb 3, 2016 | 05:44 PM
JagV8's Avatar
For the OP's V6 or your V8?
I think the V8 4.0 & 4.2 are different, at least.
Old Feb 3, 2016 | 06:29 PM
plums's Avatar
As inferred by interpreting the part number supplied by
Grant for his V6.
All of the major belt manufacturers use a standard
nomenclature that actually describes the belt to
someone who knows the system. Much like plugs,
except that each plug vendor has their own.
Old Feb 4, 2016 | 02:00 PM
Thanks, guys. I will get to it next week. The length is indeed 2730mm and it is 6 ribs. My local Ford dealer sells parts for Ford and Volvo only. According to them no Ford or Volvo uses a 2730mm serpentine belt.
rothwell
US Lower Atlantic
Mar 12, 2016 09:13 AM
Adey
Jan 31, 2016 10:10 AM
rcbarbier
Jan 30, 2016 05:20 PM
Mark7
Mark V - X 420G
Jan 30, 2016 12:11 AM
Jaguarcollector
Jan 28, 2016 08:54 PM
