S type window leak and sealing.
Old Aug 4, 2014 | 10:33 AM
JohnBJag's Avatar
Default S type window leak and sealing.
Hi there. I'm working on the seal for the windshield. Plan is to use rubber baseboard 4" moulding. Question is will 100% silicone adhesive sealant blk work to adhere to the bottom 1" of glass. So stick to rubber and glass. Or is there a better sealant adhesive such as a polyurethane based sealant such as sika flex? I have made a pattern and cut out the rubber. Next step is to glue to windshield. If successful this will make it entirely sealed. I did some water testing and it rains into the engine currently!
Thanks. John
Old Aug 4, 2014 | 12:20 PM
tbird6's Avatar
Why don't you just reseal it properly? There is no gasket as with all new glass it's glued in.
Old Aug 5, 2014 | 12:11 AM
JohnBJag's Avatar
Hello.
tbird6 thanks for the reply. I'm referring to solving the 1" stock rubber seal which is attached to the top of the plastic abs windshield cowel drain system. Water runs right through it drenching the engine. I put a garden hose on the top of the car centered and turned it on with only a 1/4" bead of water running down. The water channeled between the 2 windshield wipers into the center 1" stock rubber and ran righ UNDER it. Some water went over it into the drain system. It then flooded the rear of the engine. The windshield itself does not leak. Thoughts on this are appreciated.
John
Old Aug 5, 2014 | 02:29 AM
JagV8's Avatar
Seal has failed. Needs fixing
stanjag
Dec 29, 2024 08:26 PM
msdg137
Sep 16, 2015 06:24 AM
Jandreu
Aug 29, 2015 07:31 PM
innzane
Aug 27, 2015 07:58 PM
dpappyp
Aug 27, 2015 06:31 AM
