Sat Nav Com Screen Dead on 06 S type R
Old Aug 17, 2015 | 07:52 PM
alex ross's Avatar
Default Sat Nav Com Screen Dead on 06 S type R
hey folks thanks in advance and the NAV screen is dead on my S type R 06 and been trying a few things.... I've got C1, 50, 51 messages too.
Checked the fuse (all good)
Battery reset
Removed the dvd and dvd unit to try and reset things. It won't eject and actually doesn't seem to turn on or do anything.
I can go through the diagnostics on the screen and all the buttons will work...
Thinking I'll try to replace the DVD player unit itself first.
seems like a rather common issue however just wondering if anyone has had their DVD player unit go bad?
Old Aug 18, 2015 | 12:45 AM
JagV8's Avatar
Quite a few others on here if you Search. You can try a newer map disc (has newer firmware - available in X-Type forum for free if you look) but it only works sometimes (need new unit if not).
Old Aug 18, 2015 | 01:06 AM
alex ross's Avatar
Nod seems like a few on here but with different fixes:solutions. Thanks... I'm guessing it's the actual nav DVD unit in the trunk? The DVD won't load or eject.. Guessing a software update via a DVD won't work? Seems like a dead unit so I guess I'll try a replacement one first... Hoping that's all it is. Hottest day of the year in California and although I can live without a nav it'd be nice to have AC
Old Aug 19, 2015 | 04:56 PM
alex ross's Avatar
Well folks just as reference and to help anyone else out... it turned out my DVD player was non functioning. Couldn't get the DVD in/out. Bought a used replacement DVD player, it came alive, slotted in the DVD and the NAV screen fired right up. Case closed
Anyways for those of you out there with a DVD player and DVD that's stuck (won't come in or out and/or spin) this does/can happen....
Old Aug 19, 2015 | 04:58 PM
alex ross's Avatar
Now that everything is back to working again just wondering if I should tempt fate and/or order/update the NAV software and if so with which one? What are people using? And where should I buy it?
Old Oct 15, 2020 | 09:23 AM
jeffn's Avatar
So in a treadsurrection, my 07 screen has been working mostly but was taking a while to light up upon starting(1-3 minutes) in colder weather (read, <70'F in FLA). Now it's been more consistently off than on. Radio functions as does heat as they're controlled separately. Everything works normally when it lights up. Is this common? I searched but cannot find this precise issue.
And Yes, a new battery made no chakne in symptoms.
Old Oct 15, 2020 | 03:44 PM
scottjh9's Avatar
do you sdd capabilities....if so, you can run a d2b network diagnostic....otherwise you can pull up the trunk liner near the dvd and amp stack and check your fiber optic connections....all data to the touch screen travels through it i believe
Shdw2001h
Dec 24, 2015 11:00 AM
rf69
Oct 2, 2013 11:47 PM
200Volts
Dec 21, 2012 10:24 PM
Jsedita74
19
Aug 31, 2011 06:10 PM
Dec 10, 2006 11:14 PM
