Self leveling headlights read it gets technical
Old Sep 13, 2012 | 03:59 AM
stanjag's Avatar
Default Self leveling headlights read it gets technical
2005 S-Type 2.7D
self leveling HID headlamps.
I have to thank members of this forum for posting the information and fix to cure drooping headlights.
The screw-fix worked fine for 1 week now both lights no longer sweep up & down when ignition is on and are both permanently down.
The screw fix was required on on the LH lamp only. I have a feeling that the latest non movement has nothing to do with the screw fix.
I think that fix is well documented.
I would like to start a thread on the actual self leveling system and components. And report my findings as I try to find a cure, this will help me and I think be a great benefit to members as it seems this is rather a weak design.
First can anyone help with these basic questions.
1/ The actual mechanical mechanism.
a) Somewhere there must be a motor that actually moves the lens, where is this located, instructions to access & test
b) Any known weakness to linkage or what should one look for
2/ The electrical side. (it would seem that there is no power getting to motors)
a) Are the units fused? where are they located
b) both lights are permanently down but the illumination on all lights work. being unlikely that both motors failed at the same time, what and where are the common electrical components anyway to test these?
d) I assume both motors are on the same electrical circuit anyone got the diagram
3/ The dumb part!
I am new to the car, and not got past the fiddling with the controls stage! as everything seems to work but the are locked in the down position, are their any user controls that I might have switched off?
4/ work/test to date.
a) removed the screw fix no change so replaced screw.
b) tried to find anything on the web and in the manual. found nothing
c) stood back and scratched head, and kind of decided to ask this forum for help.
Old Sep 13, 2012 | 06:39 AM
bfsgross's Avatar
Hello and welcome stan. Yep, most of us are very familiar with the failed self-leveling headlights. I performed the screw-cure, but now that she has a warranty, the indy Jag tech hopes to have the warranty co. cover a replacement. We're not sure if Jag eventually had their supplier re-engineer the light, one would hope so.... Don't quote me; Jag forum member and certified Jag tech, Brutal, both understands the inner workings and offers to rebuild the mechanism for a reasonable fee...plus, I believe, he'll polish the tarnished lense. Hope I have the right guy. One of our moderators may be able to certify this.
Old Sep 13, 2012 | 06:55 AM
stanjag's Avatar
Default Thanks bfsgross
Thanks bfsgross for that info.
one small problem, I should have added that my S-type is UK specification and I am in England at the moment and so is my car, I have a house in Florida and have a 300C Hemi there, but I prefer the Jag in England.
back to my problem, in my case it seems that the self leveling motors are not getting power, I was hoping to get pin-out info or some info on the activation itself.
also details on remove the units and possible fixes.
Stan
Old Sep 13, 2012 | 10:41 AM
JagV8's Avatar
The JTIS on here has Electrical Guide which will likely be good enough though it strictly doesn't cover the diesel.
(Your jag couldn't be in the USA as there are no diesel S-Types there.)
For the right info pay to join jag's TOPIx.
Old Sep 13, 2012 | 11:03 AM
jag79's Avatar
I have a similar problem also. I took my my Jag to my independent Jag mechanic b/c of not auto leveling and he ran the IDS on it, it went through all the diagnostics and and the self leveling sequence, and it did work just fine! but later on after a few days later it stopped auto leveling. Dunoo whats up with that but I did do the screw method by Brutal which keeps it up and level long before. If anyone has any suggestions please let me know as well.
Old Sep 14, 2012 | 09:15 AM
stanjag's Avatar
Default where is the TFIS?
Topix,
where and what is TFIS
Stan
Old Mar 13, 2013 | 06:11 PM
docmiles's Avatar
Default New to the car, never seen anything that would be self leveling
Hi I'm new to the car and I have never seen the Carl do anything that would indicate it's leveling its own headlight. Can anyone out there Tell me what I should see when the car starts up?
Old Mar 14, 2013 | 11:13 AM
JagV8's Avatar
Stan - Never heard of TFIS. TOPIX - go to jaguar.com and click... Or google is good...
Old Mar 14, 2013 | 11:14 AM
JagV8's Avatar
See below - we have no idea what you have. Probably no self-levelling lights so no fault.
Old Mar 15, 2013 | 10:59 AM
docmiles's Avatar
I have a 2000 S-type with a V8 4.0 L engine & 82,500 miles
Old Mar 15, 2013 | 08:54 PM
bfsgross's Avatar
Your 2000 Jag S-Type doesn't have self leveling HID low beam headlamps.
Old Nov 9, 2021 | 03:22 AM
wraith388's Avatar
Default switch on effect
when dip beam selected light lenses motor down then up to the correct level. you see the beams dance down then up.
this happens if the lights are switched to dip beam THEN the ignition is switched on. Not ignition on first.
Mr. Tony
27
Jul 30, 2011 12:32 PM
studebakersui
46
Nov 4, 2010 08:36 PM
frombenz2jag
Feb 8, 2008 07:01 PM
frombenz2jag
Jan 10, 2008 10:13 PM
