Servo Doors
Old May 24, 2016 | 08:41 AM
Kewpie's Avatar
Default Servo Doors
I made a post earlier, but I think it got buried. Can a bad servo door or blend door keep the a/c from working. I have hot air blowing all across. Everything on my a/c checks out (diagnosis and mechanical). My son, who has been doing the work, said that a box behind the dash is pretty cool to the touch. Any advice would help.
Old May 24, 2016 | 11:41 AM
clubairth1's Avatar
Community Influencer
You need to read ALL the codes!
You need to check if there are any "C" codes. These are where the blend door errors are stored.
Old May 24, 2016 | 12:03 PM
Kewpie's Avatar
Don't have a reader that reads those codes. After fixing leak under supercharger, I will have to take it someplace to get that type of codes read. Still doesn't answer the question, can it cause the a/c to just blow hot air?
Old May 24, 2016 | 09:06 PM
Robinb's Avatar
If there's a ticking or gurgling noise behind the dash, more noticeable after ignition off, the actuator motors keep hunting for their base position, and the a/c may or may not be OK. If there's no noise, the door(s) may well be jammed shut and the cold air can't get through.
My STR is the same year and the same mileage as yours. I changed all 4 actuator motors about 10000 miles ago.
Get your VIN and lookup JTB00066. Actually, I had the problem even though my VIN was not in the range mentioned in the JTB.
Old May 25, 2016 | 07:42 AM
clubairth1's Avatar
That's a good point and if you have not searched to find it you should.
See if the attached TB helps.
Jack Mathews
General Tech Help
May 28, 2016 11:34 AM
xjsman89
Apr 13, 2016 12:52 AM
bullittandy
Apr 10, 2016 06:15 PM
TexMurphy
Apr 1, 2016 01:30 PM
razorboy
Mar 29, 2016 01:08 PM
