shock lower bushings? Are they available?
Old Jan 28, 2012 | 01:38 AM
qwiketz's Avatar
Default shock lower bushings? Are they available?
My jag guy said that 3 of my lower shock bushings are shot. Is there anywhere to get just that part? I finally found the source of my clunking noise while going over speed bumps.
Old Jan 29, 2012 | 03:42 PM
Biggbore's Avatar
Cool
Try racinggreencars.com SEAYA !!
Old Jan 29, 2012 | 06:38 PM
bfsgross's Avatar
Also give Coventry West (Atlanta, GA.) a call for both new and used Jag parts.
Old Mar 16, 2012 | 12:36 PM
Schoe's Avatar
Default Bushings
I had the same problem with my 1987 XJS. I took the shock down to my local hardware store and was able to match up some bushings but they were a bit too long. I cut them to size, cleaned all the burs from the cutting process, smeared a bit of anti-seize on them and they fit better than the originals. Total cost (I have 4 shocks on the back) was about 6 dollars at the store. Hope it helps.
Schoe
Old May 6, 2013 | 02:27 PM
GT42R's Avatar
bumping an old thread, anyone happen to know the answer to this? is there a lower shock bushing available? is it R specific to the CATS dampers?
Old May 7, 2013 | 12:14 PM
Schoe's Avatar
Default Shock bushing
Some time back I needed shock mount bushings for the rear shocks (all 4 of them) for a 1987 XJS Hess & Eisenhardt. The bushings that are part of the shock, the part the mounting bolt slips through, were larger than the bolts that held the shock to the lower mounts. I had to fabricate some bushings to take up the slack in the shock bushing and just slid them into the shock bushings and no more slop when the shock was bolted on. I took the mounting bolt down to the local hardware store and found a bushing that was close and that did it.
Schoe
ym37tech
Feb 8, 2016 01:04 PM
thedugger1
Oct 16, 2015 10:18 PM
Harry Dredge
Oct 10, 2015 09:33 AM
redgear
Sep 18, 2015 10:05 AM
Jagman28
Sep 14, 2015 01:37 PM
