Specifications 4 oxygen (lambda) sensors
Old Mar 25, 2026 | 08:52 PM
Roman Canadian's Avatar
Default Specifications 4 oxygen (lambda) sensors
Hi everyone,
I’m looking for the expected readings/specs for all 4 oxygen (lambda) sensors on a 3.0L V6 engine from around 1999–2000.
It seems like one of the cylinder banks is running too rich — possibly overfueling. I checked the data through the computer, and I can see that the left and right banks often show different readings on the O2 sensors.
I’d like to understand what the normal parameters/values should be for these sensors, so I can figure out whether they need to be replaced.
Thanks in advance!
Old Mar 27, 2026 | 06:31 AM
JagV8's Avatar
I'd use the fuel trims.
Do you have DTC P1111 or P1000? You always have one of those.
Are there any other codes?
Old Mar 27, 2026 | 09:58 PM
kr98664's Avatar
+1 on that. Here’s a good primer on how to use fuel trims for troubleshooting:
http://jagrepair.com/UsingFuelTrims.htm
I've never used O2 sensor voltage for troubleshooting but here’s a good guide showing what to expect:
https://www.innova.com/blogs/fix-adv...s-in-live-data
Just for giggles, I took a screenshot of my scanner:
This was on my ‘02 V6, at idle after a 30 minute drive. I forgot to note the time interval between each peak, but think it was about 1 second apart.
Note how only the upstream sensors are cycling up and down. The downstream sensors basically monitor the catalyst efficiency and health. The steady low voltage shows the cats are cleaning the exhaust. If the downstream sensors are cycling at a rate close to upstream, that means the cats are not doing enough cleaning and a code will be flagged.
Marrakechhack
Nov 20, 2024 03:56 PM
Amphicar770
Oct 26, 2017 09:00 PM
Dymaxxion
Nov 23, 2015 09:46 AM
etaent
Feb 24, 2012 12:19 PM
ThomasX
Mar 11, 2011 02:37 AM
