stype not cranking over
Old Aug 13, 2013 | 01:48 PM
tdc-motorcare's Avatar
Default stype not cranking over
hi there, new to the forum! hope someone can help..
s type v8 auto, was driving fine, parked up for a couple weeks now will not crank over.
new battery fitted
starter not clicking, also given it a few knocks.
dash lights go out as if its trying to do something.
had bumper off and checked wiring, was poor now sorted but no different,
is there anything else thats a common issue?
Old Aug 13, 2013 | 02:14 PM
JagV8's Avatar
Damp/water in trunk? Remove spare and check carefully.
May just be a seized / burnt out starter motor that finally died.
hmm, might it be the ignition switch?
Old Aug 13, 2013 | 03:08 PM
i will check for dampness tomorrow.
also tried a new battery, still the same
dash says,
1. performance limited
2.gearbox fault.
Old Aug 13, 2013 | 03:11 PM
Welcome to the forum,
It would help if you checked the codes and posted the details.
Don't forget your intro in the new members section.
Old Aug 14, 2013 | 04:50 PM
abonano's Avatar
Place the shifter into "N" then try to start the car.
When you turn the ignition key to "run" - is the "P" illuminated on the shifter? If not, your trans cable could be stretched.
Old Aug 14, 2013 | 04:57 PM
police666's Avatar
Have a look at the pats light on top of the dash, is it flashing when your ignition is on
Old Aug 16, 2013 | 11:56 AM
hi there, codes getting pulled tomorrow.
pats lights is not flashing, comes on with ignition then goes off.
P is not illuminated, none of the gear selection is.
seems to know its in park as beeps when you try to move it if the ignition is off
much appreciated for help so far.
Old Aug 17, 2013 | 09:34 AM
abonano's Avatar
If P is not illuminated - the car will not start.
Sounds like the trans cable is stretched, out of alignment or the shifter assembly is broken.
I would get the center console off to check/verify shifter operation.
Did you try to start the car in "N"?
Old Aug 18, 2013 | 05:45 AM
Hi there, can you tell me if the lights go round in sequence on ignition like clocks?
Yes, tried starting in N and still the same, however when you have ignition on, and go back to park it locks into P.
Thanks for help I will check cable
Old Aug 19, 2013 | 09:01 AM
Gearbox fault, cannon connect with gearbox. That's what the scan is saying
Old Aug 19, 2013 | 09:07 AM
Also the shifter lights don't illuminate at all
Old Aug 19, 2013 | 11:53 AM
JagV8's Avatar
Most scan tools won't connect to the TCM, if it's a 4.2. If it's a 4.0 there is no TCM so of course none will connect! But which tool was tried? If it's one that should work then go network-hunting. It's in the free JTIS.
You could help us all by filling in details as in my sig...
Old Aug 19, 2013 | 06:23 PM
Hi there it a 4.2
Today I inspected the front loom over crash bar..... Not good. Drivers corner lots of corroded wires, passengers corner 50% of the wires are blown out where water has got in, and are all split. Some even broken completely
Old Aug 20, 2013 | 01:16 AM
JagV8's Avatar
Oh dear
Disconnect battery and proceed with care.
Old Sep 2, 2013 | 05:45 PM
Now all sorted and running a dream. Front wiring loom repaired. Started first turn after repair
Old Sep 2, 2013 | 06:06 PM
Thanks for the update, good job!
Old Sep 3, 2013 | 10:36 AM
JagV8's Avatar
Hooray!
robbing
Mar 5, 2024 10:51 AM
PhilXJ6
Jan 3, 2016 08:55 PM
rocket1lf
Sep 29, 2015 09:16 AM
Paulie710
Sep 28, 2015 03:49 PM
