Sump washer size?
Old Sep 11, 2010 | 04:51 PM
1strider's Avatar
Default Sump washer size?
My 2007 6 cylinder S-type is about to get its first oil change (at least since I've had it). I'm uncertain as to what size sump washer to use. A guy at a local parts store gave me one that is about 1.8 cm outer diameter and about 1.1 cm inner diameter. I would appreciate it if someone could tell me if that is the right size and, if not what the correct size is. Thanks.
Old Sep 11, 2010 | 10:08 PM
Oldengineer's Avatar
If it's basically the same as the 3.0 in the X Type, the drain bolt has an O ring built into its head. Each time you change oil, you're supposed to replace the bolt with a new one. I was replacing mine about every other oil change, and, never had any problem.
Regards:
Oldengineer
Old Sep 12, 2010 | 08:42 AM
JagV8's Avatar
My STR has the plug with built-in seal. I also change it about every other oil change. I understand that the O ring seal IS available separately but honestly the price saving doesn't seem worthwhile.
It looks to be the same as on newer Fords (over here).
Old Sep 13, 2010 | 12:20 AM
I owned 2 X Types before my S-Type VDP - 4.2. I've been buying just the replacement bolt seal for my S - but the drain bolt for the 3.0 in the X has the O ring molded into the bolt head - so every other oil change I had to go to the dealer and buy a new bolt.
Regards:
Oldengineer
Old Sep 13, 2010 | 05:19 PM
1strider's Avatar
oldengineer, jagv8, thanks.
It sounds like replacing the plug is the way to go. The closest Jag dealer is a two hour drive away so I ordered a plug online. I appreciate you taking the time to address a novice Jag owner's concern.
Poet
Feb 7, 2025 02:18 PM
Mac Allan
Jul 20, 2020 05:46 PM
LnrB
Oct 13, 2015 12:45 AM
Collector1
Sep 26, 2015 05:28 PM
