Supercharger rebuild kit
Old Jan 21, 2012 | 10:43 PM
03Xtype's Avatar
Default Supercharger rebuild kit
Any links to company that offer bearings, seals, gaskets, and other minor supercharger items? I'm looking to freshen it up while I have it off.
This is for a 2003 Jaguar STR
Old Jan 22, 2012 | 07:50 AM
bfsgross's Avatar
You can purchase all s/c rebuild items from Stiegiemier Performance and a few other remanufacturers. There's a low mileage s/c selling on E-Bay for $650.
Old Jan 22, 2012 | 11:35 AM
03Xtype's Avatar
I will call stiegiemier, prices look high. Does eaton sell a Kit? Any one have a part number for a kit? I called 4wheelparts which eaton shows is a distributer, 4wheel asked me for a part number.
Old Jan 22, 2012 | 01:27 PM
Bacardi 151's Avatar
I think Eurotoysltd sells a rebuilt unit...We have the model M112 but I believe there's different applications that are drastically different...
There's a twin screw S/C kit that's coming out sooner or later, last I saw, it said it would be out this summer at the EARLIEST...But if you think Steigiemier is expensive...Let's just say this S/C plus install will cost pretty close to the trade in value of a 03 STR...lol
FYI...If you want loud whine noise, you can opt to seal the silencer ports...There's another thread that details it that I'll dig up if you're interested...
Old Jan 22, 2012 | 04:26 PM
zetecstr101's Avatar
how often would your s/c need rebuilding and lubed?
Old Jan 22, 2012 | 06:09 PM
03Xtype's Avatar
I'm going to try to keep my unit, just do a few minor items before I put it back on. I found that thread on the ports, I'm going to weld them closed tomorrow.
would you guys suggest swapping out the knock sensor's while i have the charger off?
Old Jan 22, 2012 | 06:12 PM
Keep her happy by keeping her cold with some nitrous... Seriously, apparently there isn't any service info from Jag...Yet you may want to look at the cobra/lightning forums and see if they recommend any routine maintenance for our Eaton M112...
Old Jan 22, 2012 | 06:47 PM
bfsgross's Avatar
My 03 STR has 125k on the clock and the blower still can blow like a cheap Singapore w$#^( (Whoa!). These M112's are both venerable and bullet proof. There are other outfits like Stieg's who can do just as good a job. Check-em out.
Old Jan 22, 2012 | 07:32 PM
03Xtype's Avatar
eaton lists this company as one of the main places in my state
Manufacturer of Supercharger kits, remanufactured superchargers and supplier of supercharger oil.
I'm guessing these rebuilders pry wont sell me origional parts.
Old Jan 23, 2012 | 08:51 AM
bfsgross's Avatar
Ask them if they port s/c too.
Old Jan 23, 2012 | 11:16 AM
03Xtype's Avatar
When I called Manufacturer of Supercharger kits, remanufactured superchargers and supplier of supercharger oil. and told them I needed a M112 rebuilt they were willing to help me. As soon as I said jaguar they wanted nothing to do with me.
Old Jan 23, 2012 | 11:57 AM
03Xtype's Avatar
the guy at Stiegemeier Porting Services, LLC - Supercharger Rebuild and Repair was very helpful, basic rebuild was priced right
Old Jan 23, 2012 | 12:33 PM
tbird6's Avatar
It's wise to change the SC oil. When is open to debate but looking at the Mustang guys running M90 and M112 blowers. I do it about every 60K miles. I get the fluid off EBay. It's a bit of a struggle to get the old fluid out but I use a spray bottle and remove the sprayer. Then stick the tube inside the oil fill port and start pumping away.
As always no room to work and you will spill oil so pack some rags in the front of the SC under the fill port to try and catch it.
Old Jan 24, 2012 | 04:58 AM
03Xtype's Avatar
i purchased the kit from SpinningWheels-SC
Old Jan 29, 2012 | 12:41 AM
03Xtype's Avatar
The supercharger is much louder, I would guess its to the point where other motorists mite think there is some thing wrong with the car.
the heat from the weld warped the surrounding area which caused the rotor to bind. it took more work then expected to finish it up
Old Jan 29, 2012 | 06:11 AM
bfsgross's Avatar
Hopefully the blower isn't warped and works well considering the time and expense involved? Mine will be sent out for a rebuild/port/polish. Otherwise, good work and write-up 03xtype.
Old Feb 17, 2012 | 09:07 PM
03Xtype's Avatar
Thank you. The supercharger is working like new with over 1000 miles on it since the rebuild
Old Feb 18, 2012 | 07:57 PM
LostnEye's Avatar
This
Old Feb 18, 2012 | 08:42 PM
plums's Avatar
GM actually has a recommended SC oil change interval - 30K miles.
mrplow58
Jan 21, 2024 05:53 AM
bdboyle
Sep 16, 2019 05:58 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
dieseldoc
Sep 28, 2015 01:17 PM
1964Daimler
Sep 9, 2015 11:20 AM
