Swaying, please help! Jaguar Tech any thoughts
Old Sep 1, 2011 | 11:34 AM
Moshu-Jaguar's Avatar
Angry Swaying, please help! Jaguar Tech any thoughts
I have a Jaguar S-Type 2000 4.0. It has a slight sway left to right from 40 to 60mph. the sway increase above 60mph. I have replaced the FRONT upper and lower control arms on both side, I replaced the lower ball joints on both sides, as well the control rod, and the struts on both sides. I have also replaced the ball bearings (hub), and the sway link on both sides.
I have not got and alignment yet for it. Everything but the struts and sway link were done at a shop, and they did the alignments then. But the waying started happening when my struts went bad. I replaced the struts and that help the sway by bring it to a slight sway. Would alignment get rid of it completely or is this due to something else, like bushings or sway bar? If so how do you tell if they are bad?
Thank you,
Damian
Old Sep 1, 2011 | 11:41 AM
bfsgross's Avatar
After all the parts/work you had put into the suspension...yes, a 4-wheel alignment is the likely cure for "The Sway".
Old Sep 1, 2011 | 11:52 AM
joycesjag's Avatar
+1 ^^^^ also are the tires worn, especially on the inside fronts
Old Sep 1, 2011 | 11:56 AM
The Chris X's Avatar
Alignment is highly suggested after strut replacement on many vehicles, depending on the suspension design. You've come this far....
You didn't mention your tire conditions. With all of your suspension issues - do you have odd or uneven tire wear? Inner edges worn off? Proper inflation?
EDIT - dang it Rick you did it again. Is it the Cleveland passive-aggressiveness towards Pittsburgh?
Old Sep 1, 2011 | 12:37 PM
Thank you everyone! Chis & Rick the tires and new as well with no uneven wear, So I will get the alignment done tomorrow and see if that solves the problem.
Thank you again,
Damian
Old Sep 1, 2011 | 02:16 PM
joycesjag's Avatar
Great minds think alike????? I just have more time on my hands
Old Sep 1, 2011 | 04:22 PM
+1 on Rick and Chris's advice especially with new tyres.
Old Sep 1, 2011 | 04:29 PM
cue244's Avatar
I had the same problem on my truck after some work was done and the alignment solved it!
Old Sep 2, 2011 | 05:02 AM
JagV8's Avatar
If alignment doesn't fix it, check out the rear suspension.
Old Sep 5, 2011 | 04:01 PM
therave's Avatar
just had a look under mine and the rear has alignment tracking setup on it, look there next
Old Oct 30, 2012 | 01:26 AM
m350's Avatar
Unhappy Hi new to the site
Hi sorry im new to the forum and apologize for sounding a bit ignorant.. I have a 01 s type with 120k miles, my car has been swayin from side to side i have done the wheel alignment twicce and im still having the same problem, my friend told me i most likely will have to change my rack n pinion? but just wanted to get you guys opinion.. again thanks
Old Oct 30, 2012 | 08:31 AM
JagV8's Avatar
Might be wise to get it professionally checked. Heck, could even be tyres (tires) - wrong rating or badly inflated for example.
Old Oct 30, 2012 | 08:40 AM
steveinfrance's Avatar
Nothing to apologise about and welcome.
Please visit New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
for a quick intro so we can all say 'Hello'
Old Oct 30, 2012 | 04:41 PM
m350's Avatar
thanks
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
kesslari
Aug 27, 2015 06:26 AM
Jaguar Forums Editor
Jaguar Press release
Aug 27, 2015 03:18 AM
