Which tint??
I have a gold S-type. I went with a black 30% tint on the sides with a 20% in the back. I believe that the brandname is LLumar.
It is working out well for me and I believe it would for you as well.
Listen to this man LLumar makes some of the best tint on the market.
Also, I wouldn't do the tint yourself unless you are extremely capable.
i have a white s type blacked out seem to get alot of comments shoudl stick with the classic black tint but then again everyone has there own preference
technically no tint is the only legal thing in PA. However when you have gone to court and won as many times as i have, its a non-issue for me. With 20% all the way around, i haven't been bothered with at all.
How did you beat that in court?? Especially with 20% all around!
it depends on how well you know the law. It passes inspection at a certified state inspection facility.......and there is no technical law for failing it during the inspection process....so if it passes the state certified inspection procedure, then you cant be dinged for it. Case closed. And i have beaten it about 6 times using this simple formula. And then i continue to reference the cases each time. And i have 20 on this car, i used to run limo all the way around. As an fyi.
SoCalJagS
Sep 27, 2015 09:20 AM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
