Transmission TSB questions
Old 03-18-2011, 03:09 PM
desertdad's Avatar
Red face Transmission TSB questions
Good afternoon, I recently picked up my 2000 3.0 from a shop here in Las Vegas. The car was surging durring acceleration. After a thorough 2 day inspection here is what I was told.
There is a TSB out from Jaguar on thisproblem and the fix is an updated valve body, cost $2300 plus labor, but in their opinion the best fix would be to buy a reman transmision, put in the valve body update, and install for a total of $6400. Also there were a few small problems else where, a hose from the coolant resevoir $290 +tax and an o-ring on the intake manifold leaking fluid 187+tax.
Has anyone else come across the surging (Cutting out) problem or the TSB, and do the rest of the quotes sound fair. I am new to Jaguar's, but have always worked on my own vehicles, even my 2003 duramax. I do not know why this car puts me off when I think about working on it.
Old 03-18-2011, 03:55 PM
Glendoramike's Avatar
A bunch of the gang here went to www.alldatadiy.com you can join and get all the bulletins for your car and see how to repair and service stuff on your car.
If it were me, I would hook up my ScanTool and go to "Live Data" let someone else drive the car and then I would see just what is going on. Try manually selecting the gears and see if it surges while locked in a gear.
Surging is usually caused by an engine problem, unless the trans is gear hunting or the convertor is locking and unlocking.
Old 03-18-2011, 04:34 PM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Maybe start with the free TSBs on this site and the previous threads.
Read any codes, you may have one of the common ones such as P0741
Live data sounds like a job for another day.
Sounds like the shop has hardly a clue and/or just thinks you're gullible and will pay a crazy sum. Are they genuinely experts on S-Types? They sound hopeless.
Surging and cutting out don't sound to mean the same - more detail?
Old 03-18-2011, 08:36 PM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
desertdad definetly get the codes read, before you ok any work if at all.
I agree with jagv8, you mentioned $187.00 to change an O-ring, well there are 2 that will be needed to be replaced. That right there is a vacuum leak that will make the tranny do all kinds of funky things. Here are 2 links associated with the IMT O-rings:
1) https://www.jaguarforums.com/forum/s...ck-pics-49214/
2) https://www.jaguarforums.com/forum/s...ics-faq-32135/
The leaking resevoir is not that bad of a replacement as well.
Old 03-18-2011, 09:54 PM
aholbro1's Avatar
Received 1,638 Likes on 1,066 Posts
$290 Is probably fair unless it actually was the hose itself. Likely they either replaced the coolant expansion tank or the radiator hose assembly, either of which is about $125 parts cost, so with labor and coolant...maybe....I'd feel better if I got a Rad hose assy out of that deal - much more labor there, ony about a 0.3 hr for a tank change. But the nipples that the small hose running between the two are prone to breakage on either/both.
I do hope you got 2 new IMT O-rings vice 1 and $187 is maybe a little steep for that service.....or...you're gonna wanna kick yourself pretty hard when you do start servicing the S-type yourself and see how easy the O-ring swap is....
Get the codes and you'll get lots of help on the surging issue.
Old 03-19-2011, 10:14 AM
desertdad's Avatar
Thanks to all for the info, one of the things I forgot to mention the check engine light has only come on once since we bought the car, it said vacuum leak in the fuel system, i changed the gas cap and it cleared itself. After looking at the pictures from Rick I think I think I will tackle the o-rings myself, it is time to get my hands dirty with this car.
Old 03-19-2011, 10:18 AM
joycesjag's Avatar
desertdad don't freak out because its a Jaguar as many mechanics do. Remember it has 4 tires an engine and a tranny just like all the others. Getting JTIS or alldatadiy is a worth while investment as is a $40.00 scanner. Good Luck!
Old 03-19-2011, 04:17 PM
desertdad's Avatar
Default Help!!!!
I cannot find the lower one. is it directly below the one I have removed, or on the other end. have it apart now.
Attached Thumbnails Transmission TSB questions-imag0024.jpg   Transmission TSB questions-imag0025.jpg
Old 03-19-2011, 04:20 PM
desertdad's Avatar
ok so I freaked a little early, it was the lower I removed first, the upper is right there under the little plastic shield.
Old 03-19-2011, 09:21 PM
desertdad's Avatar
Default job done
OK so I completed the o-ring job, my cross bar had 7 bolts on it, three broke during removal, so they had to be drilled out, replaced them with 5/16 grade 8 bolts, washers, lock washers and nuts. Also I found it was easier with my meat hooks to remove the filter and complete housing. Took the car for a test drive about 20 miles no shudder yet, we will see. Thank you to everyone who posted on this thread.
Old 03-19-2011, 11:44 PM
joycesjag's Avatar
Congrats desertdad one down! You should feel really good saving almost $200.00.
Old 03-20-2011, 03:35 AM
wcabro's Avatar
Rick,
Your posts are really valuable. I have some leakage in that area. In the spring I planned some repairs on the engine.
- new spark plugs
- rocker cover gaskets and boss seals
- replacement knock sensor P0333
- gasket inlet manifold
I have to remember to replace those two o-ring as well, maybe it will solve the leakage completely.
One question, probably you know directly: Do you know where I can find the connector of the knock sensor to the wiring loom engine compartment.
I like to check that first. The error is present only with cold start, engine hot error gone.
Thanks in advance for your answer.
Ciao William
S-Type 3.0 M70754 MY2003
Old 03-21-2011, 05:35 AM
joycesjag's Avatar
Sorry for the delay William, there are 2 knock sensors. The P0333 is the left hand sensor code which is located under the intake manifold. I am not sure as to where the actual plug is located.
Old 03-22-2011, 01:15 PM
wcabro's Avatar
Thanks for answering Rick. I think the connector must be on the rear of the engine.
I will search for it.
Ciao William
Old 03-30-2011, 04:22 PM
desertdad's Avatar
Default update
OK I will get the car back from the dealership this afternoon, new diagnosis on the sputtering #5 coil pack, I understand this is on the side of the motor where I do not have to remove the intake, but which one is it, as I am going to save a couple hundred and do it myself?
Also the transmission shifting problem is a stretched cable and shift roster, I am having them do the work for $1200, this will also cover the 100,000 mi service, new filter and fluid so I figured it was worth it.
The service writer told me one of the motor mounts and one of the transmission mounts are leaking a little fluidd, but at this time it is not a problem, are these really filled with fluid?
Next job for me the coil pack and a fuel filter (as soon as I find it).
Old 03-30-2011, 05:50 PM
Received 6,253 Likes on 5,453 Posts
Dad,
The fuel filter is in behind the drivers side wheel arch liner.
You can see a video courtesy of Vance here https://www.jaguarforums.com/forum/s...r-video-40686/
Old 03-30-2011, 11:41 PM
desertdad's Avatar
Thank you Norri I will tackle that tomorrow evening when I replace the coil pack. Any idea which one is number 5?
Old 03-31-2011, 05:29 AM
joycesjag's Avatar
edited sorry desertdad
Please refer to POST #23 by Brutal for correct cylinder numbers on a 2000 S-Type 3.0
Old 03-31-2011, 11:57 AM
desertdad's Avatar
Thank you Rick looks like I might as well replace all the spark pugs if I have to remove the manifold.
Old 03-31-2011, 12:22 PM
joycesjag's Avatar
I did when I had the intake off at 42,000 miles. The plugs did not need to be replaced but hey I was in there.
The intake removal or "set aside" really isn't that bad of a job. I can do it in less than 15 minutes (set aside method).
Quick Reply: Transmission TSB questions
