Turns over won't start
Old Dec 17, 2014 | 06:31 PM
drun's Avatar
Unhappy Turns over won't start
Charged battery, turns over, won't start, checked at fuel rail- no fuel.( bummer)!
Where's the fuel pump? Is there a reset button? I'm going to read the Jatis if I can find it. My code reader shows "no codes". $#!T.
Old Dec 17, 2014 | 06:53 PM
abonano's Avatar
Check fuse and relay for fuel pump. Also check inertia switch.
More than likely your fuel pump is toast.
Let us know what you find.
Old Dec 17, 2014 | 07:02 PM
drun's Avatar
where is the inertia switch? I can't open my JATIS because my old XP died.
If it's the fuel pump is it in the tank? How do I access it? Should I shoot this car now?
Old Dec 17, 2014 | 07:58 PM
abonano's Avatar
Under dash, drivers side right under hood release (red button) if that checks, go for fuses/relay. If those check, remove rear seat (passenger side) and pull the connector to the fuel pump and check voltage w/ ignition turned on - if you have 10.5V or higher - your pump is a goner
Old Dec 17, 2014 | 10:15 PM
drun's Avatar
Fuse is good. What's the preferred brand of pump? Consensus?
Old Dec 17, 2014 | 10:55 PM
drun's Avatar
so... How do you remove the rear seat bottom? It's dark out now so I can't see very well, thought I'd ask.
Old Dec 23, 2014 | 09:48 AM
Gus's Avatar
Gus
Check the fuel pressure first. This link is a how to.
Old Dec 24, 2014 | 05:33 AM
LoopbackZero's Avatar
The same thing happened to my S-Type a month or two ago. Fri night it drove fine, then Sat morning it would crank but not start.
I started with checking pressure at the fuel rail... none. So then I checked the fuses/relays (under the hood as well as in the trunk), and they were fine. I then replaced the fuel filter (20 mins...behind front driver's-side tire), and still no pressure.
I ended up changing the fuel pump, and she started right up. My Jag was at 126k when this happened. It took around two hours, but was amazingly simple (I literally only needed a deadblow hammer, block of wood, and needle-nosed pliers... plus, I'm not mechanically-inclined).
Be sure to keep us posted, and good luck!
Old Dec 24, 2014 | 05:39 AM
There are tabs under the back seat on each side; release those tabs and the seat comes out.
(Facing the trunk, with your back towards the engine) Remove the rubber cover on the LEFT, exposing a blue plastic ring. Use a wooden block and deadblow hammer to loosen the ring. Once the ring is removed, the top of your fuel pump housing will be exposed. Be careful not to damage the fuel lines.
Old Dec 24, 2014 | 05:40 AM
Generic... I think mine was around $150 from O'Reillys
Old Dec 28, 2014 | 03:20 PM
drun's Avatar
I used a motorcycle battery to jump the fuel pump, it's good (humming/fuel spitting from the Schroeder valve). How to check the relay? Oh and the battery keeps going dead on me.
Old Dec 28, 2014 | 03:40 PM
JagV8's Avatar
Be wary doing that as it's PWM-driven so you can cause severe damage to module or pump.
Old Dec 28, 2014 | 04:17 PM
drun's Avatar
I jumped it at the pump by disconnecting at the pump connector? what's PWM? Pulse width modulation? The pump can take momentary 12v isolated from the wiring system for a test. I'll check pump relay.
I'm suspecting low voltage ghosties from maybe the key switch going bad again or something not shutting down and draining the battery. It could still be intermittent pump fail though!
Old Dec 28, 2014 | 04:31 PM
Gus's Avatar
Gus
Below is a oneline information that should help.
Link http://www.jagrepair.com/images/Auto...01999.25en.pdf
Old Dec 28, 2014 | 05:11 PM
JagV8's Avatar
As in my .sig below and each of my posts.
Old Jan 10, 2015 | 04:57 PM
drun's Avatar
How do you get the pump housing out of the tank? Spread the 2 tabs on either side?
I'm replacing both the pump and the starter switch backend. Battery keeps draining for no reason.
Old Jan 10, 2015 | 08:19 PM
drun's Avatar
Changed the pump. Bought an Airtex from Rockauto.com and it's running again.
I charged it up all the way so we'll see if the battery holds tomorrow.
Old Jan 11, 2015 | 04:13 AM
Excellent job. I sound have mentioned it earlier, but changing the pump is a great time to change the fuel socks as well.
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
