Tyre noise
Old Apr 1, 2019 | 03:01 AM
fluty's Avatar
Default Tyre noise
I'd be grateful to anyone who has experience with and can recommend tyres that relay the least noise into the cabin. I have a 2004 S Type, lovely car, 18 inch wheels shod with Continentals. I don't know if it's the tyres or the roads, but on certain surfaces I find them very noisy. I'm particularly noise sensitive and would like to find the quietest tyres possible that are available here in Australia. Speed rating is surely not an issue with our 110 kmh speed limits, but grip particularly in the wet is important.
Thanks in advance! Michael
Old Apr 1, 2019 | 10:58 AM
wydopnthrtl's Avatar
I can give some generic advise.
Design: Assuming the tire is in good condition, concentric to the rim, and limiting the subject to tread.. here is a good read -> https://www.tirerack.com/tires/tiret...jsp?techid=310
Even wear and less noise = rotating tires **before** wear patterns develop. I recommend rotating no more than every 5k miles (8k Kilometers)
I recently installed a set of COOPER CS Ultra touring and they have been quiet so far. -> Post #11 https://www.jaguarforums.com/forum/s...5/#post1972855
Old Apr 3, 2019 | 07:45 AM
JagV8's Avatar
18" is part of the problem. 17" would be better (you keep the overall size the same and so get more sidewall). 16" if they fit over the brakes would be better still.
Old Apr 3, 2019 | 11:03 AM
I agree. So many people want short side walls. But the reduced ability to absorb bumps and uneven loads (cupped shape in road) only degrades ride and handling. There is a reason why professional race cars DON'T have short sidewalls.
Old Apr 3, 2019 | 09:20 PM
fluty's Avatar
Thank you for your interesting comment, I didn't know this - however it doesn't answer my query as I'm not about to replace the wheels!
Old Apr 3, 2019 | 09:22 PM
fluty's Avatar
Thank you, this is helpful and with information I did not know. Still wondering what tyres would be least noisy for this particular car?
Old Apr 4, 2019 | 03:45 AM
neilr's Avatar
Reviews like these might give you some pointers:
2019 Auto Bild Sports Car Tyre Test - Tyre Reviews
2019 Auto Bild Summer Tyre Test - Tyre Reviews
I would stick to reviews that are not too old though as the tyres will almost certainly have changed, even if the names are the same.
Old Apr 4, 2019 | 04:44 AM
fluty's Avatar
That is tremendously helpful - everything is covered!
Thank you very much for taking the trouble to reply,
Michael
Old Apr 6, 2019 | 07:00 AM
hilary's Avatar
In response to your tyre noise....
I recently purchased another str and had the entire car looked and was told tyres were still good.
I was heading out to dinner one night noticed the tyre on the driver back seemed lower i went to add and it seemed resistent to take the air at first but did. I went to dinner than 2 hours later headed home and it was SO LOUD!!!!
i got home went to touch the tyre to check it out and the rubber was hot.
Next day i went ti get a replacement they said you dont need it. Has not done it since. Very odd....
Old Apr 6, 2019 | 10:46 AM
JagV8's Avatar
Something else, then.
Dragging brake which has since released?
Bearing on its way out?
Whatever it it s it'll probably do it again.
Delta66
Apr 21, 2014 10:30 AM
Royston
May 15, 2013 06:23 AM
RaceDiagnostics
Feb 18, 2013 02:56 PM
HBZ
Jan 10, 2010 05:43 PM
