Ugggg Now no A/C
Well
I had very little heat during the winter and now I have no A/C ,I Serviced A/c It was just about 11oz low on freon , but still no a/c ,Compressor does Not kick on , the climate control apears normal to look at and work, the heater control valve feels hot but I can barely Reach it much less get the wire Unplugged , Iv been trying this diagnose DIY but no luck so far
DIY: Diagnose It Yourself - JaguarClimateControl.com
any ideas ???
any ideas ???
May well be best to get actual diagnostic via jag tool of the climate module.
Or, it's possible to laboriously go around the various sensors (temp, humidity, pressure) and actuators to fault-find.
ok i diagnosed it old school I have power to clutch while running and its not engaging
(compressor clutch is toast ) and the center spins while not running so who wants to fix it ? I sure Dont
Did you fix the leak or just recharge?? I am a bit confused because you can't properly recharge the system if the compressor is not turning??
11 oz. is a huge amount to put in. The system was almost empty. You lost oil too so did you add any oil back with the Freon?
Did you change the DCCV yet? I would for sure get this done now along with a good coolant flush and refill.
Be sure and flush the heater core separate from the engine. It has three hoses and I flushed all of them. That way you are flushing back and forth thru the heater core. I clamped more heater hose on the Aluminum tubes going to the core so I could get the hose outside the engine compartment and get my water nozzle taped to the heater hose. Then blast with water. Hold one of the other two pipes closed with your finger and then alternate. Then move the water hose to the next pipe. Do all three pipes.
I never did see anything come out of the heater core but I got my heat back as soon as I filled everything back up!! I still can't explain it but it's cheap and pretty easy so just do it!!
Im opting to sell car asap Its nice but no a/c and some other normal codes vacuum leak I was planning on fixing but maybe not now . black with tan interior no Nav newer conti tires all weather How Much ? 165 K
Really bets anyone , We will see maybe I can bring the resale value up for all of us daily drivers , I just sold a focus for 3 grand with over 100k miles with rust all over it and dents I should easyily be able to get twice that for a jag , bottome line is someone wants it bad they will pay Motor runs perfect and so is the rest of the car .
Im happy to let you All Know I have A/C Now woooooohoooooo!!!!
value of the car just went up to 7 k LOL
I fixed it my self , the dealer wanted 2500 local import shop wanted 1470.00
and it still has the same compressor and clutch , your never going to beleive how I fixed it .
-put air in the tires?
-did a search?
-kissed the dog?
-beat the ole lady?
