Ugggg Now no A/C
Old Apr 10, 2013 | 10:46 AM
03styper120k's Avatar
Default Ugggg Now no A/C
Well
I had very little heat during the winter and now I have no A/C ,I Serviced A/c It was just about 11oz low on freon , but still no a/c ,Compressor does Not kick on , the climate control apears normal to look at and work, the heater control valve feels hot but I can barely Reach it much less get the wire Unplugged , Iv been trying this diagnose DIY but no luck so far
DIY: Diagnose It Yourself - JaguarClimateControl.com
any ideas ???
Old Apr 10, 2013 | 11:04 AM
JagV8's Avatar
May well be best to get actual diagnostic via jag tool of the climate module.
Or, it's possible to laboriously go around the various sensors (temp, humidity, pressure) and actuators to fault-find.
Old Apr 10, 2013 | 11:21 AM
Default no a/c
well with 165 k on it who knows whats up but will the normal scan tool showw anything regarding climate control
Old Apr 10, 2013 | 11:29 AM
Default pressure sensor
Is the low side pressure sensor on the top drivers side with 3 wires connected to it ? or is it the high side i wouild think low side but not sure if this is the problem
Old Apr 10, 2013 | 12:15 PM
Does this help?
Old Apr 10, 2013 | 12:31 PM
JagV8's Avatar
No. That's why I said jag tool.
Old Apr 10, 2013 | 01:09 PM
ok i diagnosed it old school I have power to clutch while running and its not engaging
(compressor clutch is toast ) and the center spins while not running so who wants to fix it ? I sure Dont
Old Apr 10, 2013 | 01:12 PM
tbird6's Avatar
Did you fix the leak or just recharge?? I am a bit confused because you can't properly recharge the system if the compressor is not turning??
11 oz. is a huge amount to put in. The system was almost empty. You lost oil too so did you add any oil back with the Freon?
Did you change the DCCV yet? I would for sure get this done now along with a good coolant flush and refill.
Be sure and flush the heater core separate from the engine. It has three hoses and I flushed all of them. That way you are flushing back and forth thru the heater core. I clamped more heater hose on the Aluminum tubes going to the core so I could get the hose outside the engine compartment and get my water nozzle taped to the heater hose. Then blast with water. Hold one of the other two pipes closed with your finger and then alternate. Then move the water hose to the next pipe. Do all three pipes.
I never did see anything come out of the heater core but I got my heat back as soon as I filled everything back up!! I still can't explain it but it's cheap and pretty easy so just do it!!
Old Apr 10, 2013 | 01:30 PM
We were using a A/C Mcahine you can siphon it down and recharge with correct amount of freon and install correct oil without motor running , we did a siphon pressure test with no leaks found after 15 minutes , then we recharged and started at that time compressor should of started working as far as being low on freon It was still evacuting when I looked so basicly it held 1lb and 11 oz from what the sticker said not sure on how much we took out . , and it seems like the ccs is working fine in the cab a/c should be Running if clutch worked it has over 12volts to it and is not engaging
Im opting to sell car asap Its nice but no a/c and some other normal codes vacuum leak I was planning on fixing but maybe not now . black with tan interior no Nav newer conti tires all weather How Much ? 165 K
Old Apr 10, 2013 | 04:34 PM
tbird6's Avatar
It's gone to be a low sale with 165K! Do you have a price in mind?
Old Apr 10, 2013 | 11:23 PM
Default low sale
thinking 6000.00
Old Apr 11, 2013 | 09:27 PM
abonano's Avatar
thinking 6000.00
Think lower, much lower....
Old Apr 12, 2013 | 07:56 AM
Really bets anyone , We will see maybe I can bring the resale value up for all of us daily drivers , I just sold a focus for 3 grand with over 100k miles with rust all over it and dents I should easyily be able to get twice that for a jag , bottome line is someone wants it bad they will pay Motor runs perfect and so is the rest of the car .
Old Apr 12, 2013 | 08:06 AM
Im happy to let you All Know I have A/C Now woooooohoooooo!!!!
value of the car just went up to 7 k LOL
I fixed it my self , the dealer wanted 2500 local import shop wanted 1470.00
and it still has the same compressor and clutch , your never going to beleive how I fixed it .
Old Apr 12, 2013 | 08:27 AM
Well?
Old Apr 12, 2013 | 09:01 AM
joycesjag's Avatar
-BFH?
-put air in the tires?
-did a search?
-kissed the dog?
-beat the ole lady?
Old Apr 12, 2013 | 09:07 AM
Gus's Avatar
Gus
OK I give up!
Old Apr 12, 2013 | 10:01 AM
JagV8's Avatar
I don't care. Not worth 6K.
Old Apr 12, 2013 | 12:12 PM
tbird6's Avatar
Hey that's not fair!! Let us in on the secret!
Old Apr 12, 2013 | 05:26 PM
abonano's Avatar
Super freon and duct tape? A/C Repair in a Can? C'mon... out with it...
