Vibration and steering shimmy
Old Oct 20, 2016 | 03:03 PM
zigzewel's Avatar
Default Vibration and steering shimmy
Alignment good, tires replaced and balanced.
Where to look at narrowing down? Suggestions I got were drive train, but there's three, how to tell their ok? Any front end things to look for?
Old Oct 20, 2016 | 03:20 PM
JagV8's Avatar
When does it do it? When doesn't it?
Old Oct 20, 2016 | 04:17 PM
zigzewel's Avatar
Mostly after 80KM/hr on the highway, the winter tires are making it more pronounced. I also had them make sure the rims were true when they did the balance.
Old Oct 20, 2016 | 05:24 PM
Gus's Avatar
Gus
Have your shop look at both lower ball joints and your rack control arms. I recently had to replace both vertical control arms with ball joint and the steering rack for that same reason. Jaguar had a TSB on the ball joints. I also had to replace the bushings on the left lower control arm. Found it by lifting action on the rear wheel with the car off the ground.
Gus
www.jagrepair.com
Old Oct 20, 2016 | 05:51 PM
Geezer's Avatar
See this TSB for Shimmy/vibration problems.
http://www.jagrepair.com/images/TSB/...0Vibration.pdf
Old Oct 20, 2016 | 06:28 PM
zigzewel's Avatar
Thanks, on it....
I assume if I give the local jag shop my VIN, can they tell me these have been done? Do I have to push a little? Are they reluctant, especially a 17 year old car! lol
Old Oct 20, 2016 | 07:02 PM
Geezer's Avatar
The dealer should be able to tell you if the TSB was done on your car. As for getting it repaired now, probably not as it was not a safety recall.
Old Oct 20, 2016 | 09:08 PM
Gus's Avatar
Gus
Sounds like a ball joint.
Gus
www.jagrepair.com
Old Oct 21, 2016 | 09:42 AM
zigzewel's Avatar
Originally Posted by Gus
Lifespan?
Old Oct 21, 2016 | 10:32 AM
JagV8's Avatar
Varies. Till they fail.
Things like driving on rough roads makes them wear.
Old Oct 22, 2016 | 09:30 AM
zigzewel's Avatar
Default Update, more confused now.
OK, so, last night, driving home from a dinner, Nothing, I mean, maybe a little vibration, but driving on Goodyear Winter Ice treads I'm going to expect some. But nothing like the day I first posted, WTH? Now I'm really confused!! And sound a little flaky.
Old Oct 25, 2016 | 03:29 AM
neilr's Avatar
If the vibration is intermittent, it could just be flat spotted tyres which revert to round as they warm up. The S-Type seem particularly sensitive to it.
Old Nov 6, 2016 | 03:13 PM
Catmobile's Avatar
If it does it more at higher speeds, 65 mph plus, one or more wheels might be bent or damaged. Have a tire shop put your wheels with tires on the spinner and see if they spin nice and true, or wobble around. It happened to me with a couple of different cars and I replaced the bad wheels. Try this before you tear the car apart.
Old Nov 7, 2016 | 04:07 PM
zigzewel's Avatar
I did and they said theydid, I told them that I wanted to rule it out so they were extra careful to check, they said nope, look good, but pointed to the tire wear and said alignment, which is another story, I had it aligned, but the mechanic took it to another place and I don't trust that he gave them Brutal's (?) spec. I did call the alignment shop, they said they don't keep the spec, and that vibration and shimmy is not alignment, regardless, bring it in with your spec and we'll check it. Which I should do anyway before I ruin another set of tires.
Old Nov 28, 2016 | 04:05 PM
zigzewel's Avatar
Update, changed the sway bar bushing because of the horrible squeak, (see other post I made) and it has cleared up all the vibration. Oh man, I'm so happy, cost me $30 Cdn, instead of the $1000's the repair shop wanted to charge for a used drive shaft. I'm a happy boy. One by one I'm knocking them down.
Old Nov 29, 2016 | 06:47 AM
Jon89's Avatar
Now that's a steal of a fix. Congrats....
Old Nov 30, 2016 | 03:41 PM
TonyX's Avatar
I'm happy to hear your issue was resolved but I'm having hard time understanding why. Why would stabilizer bar bushing cause or not cause wheel vibration? Inquiring minds want to know. Thanks.
Old Nov 30, 2016 | 08:21 PM
plums's Avatar
Those are the bushings on the bar itself, correct?
Did they look like they were binding?
Old Dec 1, 2016 | 08:39 AM
zigzewel's Avatar
I'm not too sure, it certainly wasn't my expectation that getting rid of the squeaky bed spring noise would remove the vibration at all!
Old Dec 1, 2016 | 08:42 AM
zigzewel's Avatar
Too me quite the opposite, the bushing (yes, sits "around" the bar) seemed a little crushed. And, as I mentioned in the original post, the bottom bolt didn't seem all that tight, was it tight when the bushing was put in originally and then as the material degraded it became loose? Might be something for me to check on the other-side, the one I avoided because the DCCV is my arch nemesis.
