warm on drivers side
Old Jan 14, 2008 | 09:42 AM
FactoryJaguarTech's Avatar
Default RE: warm on drivers side
take a big prybar and bang on the dual coolant control valve. Standing in front looking down, will be to you left under radiator hose. Easier if you have to replace it to pull fan pack to access. Valve has two solenoids on it.. Common fault.
Old Jan 14, 2008 | 10:57 AM
Good advice!
If you search you'll find many threads on similar problems, sometimes a good thump works wonders.
Old Jan 14, 2008 | 07:00 PM
YoungABS's Avatar
I just got back and pulled my cat out of storage and I am having the same issue just flip flopped. My heat is even suspect. I'm going to take it in tomorrow.
Old Jan 14, 2008 | 07:18 PM
If it is 2000-2002 then also you want to check the expansion tank. Make sure it has plenty water then run vehicle. Once up to operating temp, make sure it is not leaking by drivers wheel. That also is a common source of no heat. The heat on one side and cool on other is likely the dual coolant valve.
Old Jan 15, 2008 | 06:19 AM
Have seenthe problem, however I like starting at the simple point and cheapest route first. Good find!
Old Jan 16, 2008 | 05:09 PM
jag_genius's Avatar
have seen also climate control module not putting out a signal and also a corroded front harness.
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
Dicque
Sep 19, 2015 12:53 PM
avern1
Sep 8, 2015 06:25 PM
