Warped Rotor
Old Oct 9, 2010 | 02:46 AM
Staatsof's Avatar
Default Warped Rotor
Originally Posted by vance580
Be on the lookout for my brake video that will be up next weekend. I warped a rotor so I'm installing new rotors next weekend so will be doing a brake video for you guys and will post up another thread once its done. Will be a how to on the STR Brembos front and rear.
Warped a rotor! What sort of bad boy behavior was involved? ;>))
I haven't done the brakes as yet but I am changing pads and touching up my wheels, soon hopefully. So I'm looking forward to that video.
Bob S.
Last edited by H20boy; Oct 12, 2010 at 08:25 PM. Reason: added quote from vance, from the headlight thread; sorry mispelled rotor 1st time
Old Oct 9, 2010 | 04:36 AM
JagV8's Avatar
Warped an STR rotor!! They're not thin and crappy y'know!!
hmm, stopped with brakes applied (pads in contact) with very hot rotor?
Old Oct 9, 2010 | 07:55 AM
vance580's Avatar
I believe its a rear that is warped. It may have been warped when I bought it. I dont have any highways near me so the highest speed limit near me is 55mph. Well took a trip for a family reunion and on some back roads was getting some pretty bad pedal pulse from slowing down at high speeds. Doesnt pulse when driving slow and braking only when slowing from about 60+. So I think its my rears. I also still have some noise when driving really slow that I thought was the 2 piece lugs, well I no longer have the 2 piece lugs so I think its the rotors contacting the parking brake pads cause I'm getting a weird wear line on the rears. I picked up the crossed drilled and slotted black ones from brakeperformance.com so I'll give them a try and since the rotors dont seem heavily warped I'm gonna turn which ever set I find warped and have them on hand as spares.
Old Oct 10, 2010 | 09:14 AM
Staatsof's Avatar
Sometimes it pad material deposition and not actual warpage. If you're using cross drilled rotors that might be an issue as well. Pad material can accumulate in some of the holes, build up and cause pedal pulsation. That's why I never put them on my cars. I've see too many issues with that. It might not be that in your case but it's worth a check. You can usually clear the holes with a drill bit or knitting needles.
Bob S.
Old Oct 10, 2010 | 09:52 AM
vance580's Avatar
Bob S.
I'm upgrading to the drilled/slotted rotors. The ones that I believe are warped are solids. I just figured I'd get new ones now and have the back ups as I will soon be unemployed so trying to get anything little that could become big fixed now while I still have an income. I'll be having them checked for warpage and if they are good and its something else I'll just keep the solids as spares.
Old Oct 11, 2010 | 10:13 AM
Staatsof's Avatar
Oh OK. Well if there's still time skip the drilled part.
You can get pad material deposition on smooth rotors as well.
Bob S.
Old Oct 11, 2010 | 10:58 AM
Brutal's Avatar
There are several issues with brake pulsation
1 warped hubs
2 warped rotors
3 rust on rotors not where pads sat
explanation,,you always need to measure runout and parallelism of rotors with a dial indicator if you suspect warpage. .002 or less is spec with lug nuts torqued to spec after wheel is removed.
If its over .002" remove the rotor and check hub same spec.
Replace anything thats over .002"
parallelism is checking thickness variations of the rotor. This many times is the result of a car sitting and the rotors rusting where the pads do not sit. Then when you drive the car and brake the rotors are cleaned of rust which as we all know is the oxidation of metal. When the rust is cleaned, that metal is gone. Problem is that now the spots where the pads sat was not rusted and those spots are now high spots and create pulsations too..
Old Oct 11, 2010 | 12:28 PM
vance580's Avatar
1 warped hubs
2 warped rotors
Thanks for the info BRUTAL. I needed a reason to pick up a dial indicator and you just gave me one. I'll check them once my new rotors come in and I tackle this job. If its 3 and I have enough rotor left for turning I'll have them turned true and they will be my back up rotors.
Old Oct 11, 2010 | 01:42 PM
H20boy's Avatar
moved your posts over here guys, it was muddying up the headlight fix thread...tsk tsk
Old Oct 11, 2010 | 01:53 PM
Brutal's Avatar
But I like mud, hense the 4x4 truck
actually I hate mud or the cleanup of it.
Just make sure you check the runout of the hub if the rotors are out of spec. I just did a car last month that another shop replaced the Brembo pads and rotors for brake shimmy and the problem was still there lots of $$$ later. Needless to say the owner wasnt happy when I told him he only need a hub and not the new pads, and rotors. The hubs should really be "0" in my opinion cause ANY out of spec is multiplied out to the end of the rotors. IN his case the hub was .002. the new rotors were .007. After I put a new hub in, the same rotors were then at .001"
Old Oct 12, 2010 | 02:45 AM
Staatsof's Avatar
But what the heck causes a hub to go out of spec like that?
I've had them with gunk/rust/build-up on them.
Bob S.
Old Oct 12, 2010 | 03:06 AM
JagV8's Avatar
Potholes, kerbs, etc?
Old Oct 12, 2010 | 06:18 AM
Staatsof's Avatar
I would think that it would have to be a major event that also destroyed a wheel or suspension pieces as well. So you know that something major had happened.
Bob S.
Old Oct 12, 2010 | 03:26 PM
vance580's Avatar
This weekend when I get my rotors I'm gonna make a side video showing how to measure runout. That way if you think you may be having a problem you can check before buying new rotors. I hope mines good I'd really hate to have a bent hub. BRUTAL if my hubs out of spec does that effect the halfshafts in the rear at all?? Also would the bearings be shot also or would I be good with just a new hub??
Old Oct 12, 2010 | 05:42 PM
Brutal's Avatar
It depends on why it bent, potholes, lightly damaged bearing if hub is bent. On a stype they come as an assembly. Im working on a 03xk right now that has 2 bent hub .005, and .007 the rotors are .009 and .015. 2 new hub and bearing and ill recheck when done, but past experiance has shown that the rotors are normally ok if the hub is warped. Once the hub is fine then the rotors run true(normally)
Old Oct 12, 2010 | 06:05 PM
vance580's Avatar
Well even if my rotors are fine I'm still installing these bad boys that the brown truck just brought me today. Hopefully I'll only have 1 bent hub if any as I'm seeing they arent cheap.
Thats a standard 8.5x11 sheet of paper couldnt find my ruler.
kthrash
Feb 25, 2019 10:20 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
