Water and rough running.
Old Jan 19, 2025 | 01:58 PM
scrannel's Avatar
Default Water and rough running.
Suddenly getting what looks like a lot of condensation from the exhaust area (approximately) and rough running. Coolant level is good. Thanks
Old Jan 19, 2025 | 02:35 PM
JagV8's Avatar
Would be worth using OBD live data.
Get engine warmed up and then park.
Check whether running OL (open loop) or CL (closed loop).
If CL, watch fuel trims. What are they and how steady?
If unsteady or not near zero, rev to about 2500 and are they steadier / nearer zero?
Old Jan 19, 2025 | 04:58 PM
scrannel's Avatar
Thanks JagV8, however I am currently picking up the pieces of the Palisades/Malibu fire, a bullet we thankfully essentially dodged. All I can say at this point is it seems to smooth out at higher RPMs. The only other thing I can say is we just went through a massive change in humidity overnight -- and the air is full of crap. Thanks
Old Jan 19, 2025 | 05:15 PM
JagV8's Avatar
Ouch - you have my heartfelt sympathies!
Stay well.
Old Jan 19, 2025 | 05:58 PM
NBCat's Avatar
Originally Posted by scrannel
...I am currently picking up the pieces of the Palisades/Malibu fire, a bullet we thankfully essentially dodged. ...
Hopefully you and your family are all safe!
If the vehicle was sprayed with fire hoses, it may be best to open the bonnet and let everything dry out. If there's a misfire, don't drive the vehicle if the MIL begins to flash or catalyst damage is the result.
Old Jan 19, 2025 | 07:14 PM
scrannel's Avatar
Thanks! No fire hose but super humidity and leaving hood open. Bonnet too!
Old Feb 22, 2025 | 08:17 AM
scrannel's Avatar
Wanted to close this out -- was RATS... chewing on wires.
Old Feb 22, 2025 | 08:19 AM
JagV8's Avatar
Oh no! Good luck.
Thanks for posting the cause.
Old Feb 22, 2025 | 08:09 PM
scottjh9's Avatar
Stinking rats. Hopefully the wire colors are still visible for easy repair. I had to do a few splices on my car because of wire rot. Jaguar did not give much slack in the harness
Old Feb 23, 2025 | 07:57 AM
scrannel's Avatar
I've been using some of those "sticky" traps and caught what looks like a baby kangaroo! Wires were fixable.
sarahsmi
Sep 8, 2017 03:20 PM
louvit
May 8, 2016 10:34 PM
innzane
Aug 27, 2015 07:58 PM
colin3342
Apr 19, 2013 08:43 AM
disguay
Jan 26, 2012 08:44 AM
