Weird issue
Old Jan 28, 2019 | 11:03 AM
Uno Strzelichowski's Avatar
Default Weird issue
So my s type 3.0 2001 managed to start somehow after a cascade of fixing it. I don’t know what I did but as soon as I start my car the battery lights go on and everything shuts off. My engine still runs however it’s just all the electrics shut off; my speedo and tacho goes to 0 and all my gauges are gone and none of my consoles work. Maybe it’s the alternator but I don’t know.
Old Jan 28, 2019 | 03:20 PM
kr98664's Avatar
Several thoughts:
Please give us a quick rundown on recent vehicle history. You've had several threads going and I can't remember exactly what has been done. I vaguely remember new head gaskets and a new alternator, but am not positive.
If the alternator is new, most aftermarket brands won't communicate properly with the car. It will charge just fine, but the little red battery symbol stays illuminated.
Please make sure the battery is fully charged before doing anything else. This is VERY important. Your description sounds like a dead alternator and a partially discharged battery. When voltage drops low with the engine running, most non-essential functions (gauges, for example) are shut down to save energy for ignition and fuel delivery.
Check the alternator output. On an early model, you should see about 13.5v at the battery.
Old Jan 28, 2019 | 03:40 PM
Busa's Avatar
I had some similar weird stuff going on with my 2.5 V6 last year.
It was a poor battery connection on the earth lead.
Previous owner had fitted a battery clamp that looked like it came off a tuc tuc.
Looked ok connection until I loosened it and took it off to clean it then the clamp fell apart.
Got a proper battery clamp now with quick disconnection without removing the battery clamp.
Old Jan 28, 2019 | 03:44 PM
Busa's Avatar
Another thing, check the boot/trunk for water ingress.
Not uncommon on the S type to have water splashing around which if it gets deep enough can wreck the electrics in the boot.
Old Jan 28, 2019 | 08:34 PM
Thank you for all of your replies. I’ve replaced the head gasket and exhaust valves. Battery doesn’t look discharged but it could be better. Alternator seems fine too as it does spin and produce some sort of current. Battery cables sound like the problems because of prior issues and horribly designed clamps. I’ll definitely replace those as soon as the weather gets better. Thanks
Old Jan 29, 2019 | 11:22 AM
S-Type Owner's Avatar
You have to get the electrical issues sorted in order to form a baseline for further troubleshooting. If the alternator just produces "some sort of current" and the battery and cables are marginal, the car is highly unlikely to run properly and spurious codes, together with electrical gremlins, will continue to the the order of the day...
Old Feb 2, 2019 | 05:10 PM
Ok I’ve managed to swap out the battery cable and the problem still persists. I measured the currents and the alternator is producing around 18 volts. I took it for a spin and it stalled and same problem with gauges shutting off when stepped on the accelerator.
Old Feb 2, 2019 | 05:50 PM
18 volts is too much on a 3.0; the charging voltage should be 15-15.5 volts. Also what is your static charge at the battery after loosing the surface charge by leaving the headlights on for three minutes? Improper pre-start voltage can cause all sorts of gremlins...
Old Feb 2, 2019 | 06:40 PM
scottjh9's Avatar
do you have a way to read jaguar specific codes....the car electronics protect themselves for an over or under charge....18 volts is definitely over as S-Type Owner stated....an over voltage will set a code in a few modules I know because it happened to me when my alternator went bad...luckily I was in the driveway, and the same thing happened...all sorts of strange lights and the car shut off...I ended up being able to re start and got 18.5 volts reading and replaced the alternator with a used oem one.....there are a few different alternators that will fit these cars, so you have to get exactly the same jaguar part as the old one.....especially if it has the "smart charge" system
Old Feb 3, 2019 | 10:54 AM
JagV8's Avatar
At 18V don't be surprised if some modules are damaged.
xjrwithproblems
19
Nov 18, 2014 01:28 PM
cadrad
Dec 27, 2013 05:30 PM
MARVSGT
Mar 16, 2011 03:18 PM
hey_nav
Dec 23, 2010 02:43 PM
jvegas
Jan 13, 2009 09:31 PM
