Wheel Hub / Steering Knuckle Tolerances - Should it be a tight fit?
Old Aug 15, 2022 | 05:37 AM
Zalastar's Avatar
Default Wheel Hub / Steering Knuckle Tolerances - Should it be a tight fit?
Greetings,
I recently purchased a 2001 S Type 4.0 which I have been restoring and when I went to have it aligned I was told it needed a front wheel bearing. Rather than paying Les Schwab $489 to do the work I purchased the part for around $60 at Rock Auto. When I removed the old wheel hub I was surprise to find that it slipped right out after removing the 4 bolts. I was under the impression I would have to remove a couple wheel studs and "press" it out using a couple cap screws and nuts. When installing the new hub I was able to push it into the knuckle by hand. My question is as to whether my steering knuckle is worn and should be replaced? Should that be a tight fit? There isn't any play in the fit but I expected to have to "press" it in when tightening the 4 retaining bolts.
Thank you for your time in advance
Old Aug 15, 2022 | 06:18 AM
Zalastar's Avatar
I did not see an edit button on the thread so I could not edit the title but I think what I am referring to as the "steering knuckle" is actually called the "vertical link" according to Jagbits
Old Aug 15, 2022 | 09:43 AM
motorcarman's Avatar
When the hub/vertical links become CORRODED, then you need to start worrying about presses and BFHs.
The are not supposed to be a 'press-fit'.
Old Aug 15, 2022 | 09:47 AM
Zalastar's Avatar
Excellent news. I used a dab of anti seize on the inside of the vertical link as well. Thank you so much
Old Aug 18, 2022 | 09:44 AM
clubairth1's Avatar
Community Influencer
Great idea on that Anti-Seize! Wish more mechanic's would think of that during repairs too.
denis4x4
Dec 16, 2021 04:45 AM
JessN16
Aug 5, 2016 09:24 AM
innzane
May 23, 2015 07:56 AM
Heliwilly
Oct 30, 2014 03:07 PM
phaelax
Apr 5, 2013 08:05 PM
