Where are the IMT-O rings on the 4.0L
Old Mar 2, 2016 | 11:21 PM
Mihai Gherghina's Avatar
Default Where are the IMT-O rings on the 4.0L
So I'm having a difficult time trying to locate the IMT-O rings for my 2001 4.0L stype. I feel like there might be a bit of a vacuum leak, but also I'd just like to know. All the guides I've seen are for the 3.0L and it seems to be very different in terms of location
Old Mar 3, 2016 | 05:41 AM
joycesjag's Avatar
Well you should be happy to hear that your 4.0 does not have IMT o-rings, so you can mark that off your list as possibilities.
Old Mar 3, 2016 | 10:17 AM
NBCat's Avatar
Originally Posted by Mihai Gherghina
So I'm having a difficult time trying to locate the IMT-O rings for my 2001 4.0L stype. I feel like there might be a bit of a vacuum leak, but also I'd just like to know...
Use an ELM, or other such device, to check short term and long term fuel trims if you suspect a vacuum leak. The 4.0 litre has many plastic connectors and pipes that deteriorate with age causing small leaks.
Old Mar 3, 2016 | 09:10 PM
JBzXJ40's Avatar
Mihai,
What symptoms do you have, is it a rough idle, consistent or intermittent? Is it slow to rev up? Are there any messages displayed on the message center such as a " Restricted Performance "? Being that its a V8, there could be numerous places that a vacuum leak could be coming from, need a bit more info.
As JoycesJag said, only the 3.0L V6 S-type and X-type had the intake manifold tuning valves, the V8's never had that setup.
Old Mar 4, 2016 | 01:52 AM
JagV8's Avatar
+1 on elm327.
JTsmks
Mar 17, 2021 04:02 AM
JagnJeep
Mar 7, 2016 05:33 PM
Mark1975
Mar 7, 2016 01:41 PM
Jagman28
Feb 29, 2016 08:40 AM
harvest14
Feb 26, 2016 10:43 AM
