wierd beepng.. "transmission fault" PLEASE HELP.!!
Old 02-25-2011, 01:52 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Or if the battery is dying - in which case the charging system even if 100% OK cannot overcome the battery's state. You need a really good test to check a battery is fit for a modern car's electronics.
Old 02-25-2011, 08:54 AM
Jayt2's Avatar
Received 18,489 Likes on 7,455 Posts
Get a hygrometer and check each cell of the battery, there could be a weak one that a voltage check may (or may not) find. This way is the best way to check a battery...
Good luck.
Old 02-25-2011, 09:08 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
It is hard to truly test your battery accurately at home. With today’s technology all you need to do is take it to AutoZone, Sears, PepBoys or whatever and have them give it a test. They have the equipment to test it properly leaving out the guess work.
Old 02-25-2011, 10:42 AM
JagV8's Avatar
Gus - I think we've seen several people who've done that and the battery was deemed OK, but it wasn't and after further grief they've replaced it with finally a cure for their problems.
Old 02-25-2011, 04:07 PM
Gus's Avatar
Gus
Gus is offline
You are correct!
Old 02-25-2011, 05:46 PM
STRaightJAGgin's Avatar
i will buy a new battery this weekend.. any suggestions?? i cant seem to find an Optima Battery that will fit my STR..
Old 02-25-2011, 06:04 PM
Gus's Avatar
Gus
Gus is offline
I hope you are getting the battery because you need it and not because we are suggesting you get a new one. If it tested bad you are doing the right thing.
  #28
Old 02-25-2011, 07:42 PM
well it tested "Good Battery" at AutoZone so i guess im not doing the right thing??
i ran a quick test with my neighbors multimeter.
DCV20 with the car off. 12.41
DCV20 with the car on. 14.41
are these #'s those of a bad battery??
Old 02-25-2011, 08:06 PM
Gus's Avatar
Gus
Gus is offline
Good meaning what? It is holding the voltage required or is it satisfactory. It seems that satisfactory is nor suitable for these cars. Do you know how old the battery is? If all is good clear your codes and see if you still have the problem.
  #30
Old 02-25-2011, 08:35 PM
androulakis's Avatar
Wait. That 14.41 volts seems a little bit high with the car running. Almost like the voltage regulator in the alternator isn't working right. Typically you see something around 13.8v with the car running.
Does anyone else agree with me on that?
Take care,
George
  #31
Old 02-25-2011, 08:45 PM
Gus's Avatar
Gus
Gus is offline
Thanks George, I thought it was high and was looking for supporting information but was unable to find it. I had not had reason to dabble with the voltage output from the alt.
  #32
Old 02-25-2011, 08:56 PM
aholbro1's Avatar
Received 1,638 Likes on 1,066 Posts
Depends how cold it is, so-to-speak....
File Type: pdf
androulakis (02-25-2011)
  #33
Old 02-25-2011, 09:02 PM
Gus's Avatar
Gus
Gus is offline
If we determine that the battery is good then I would suggest checking the TB plug for a clean and tight connection.
  #34
Old 02-26-2011, 02:26 AM
JagV8's Avatar
14.4V is NOT high. It's the way these cars work when initially recharging. All in JTIS.
The voltage you need is the LOWEST during CRANKING. That's what the modules suffer. You need to measure any voltage spikes/drops even of SHORT duration, say 1ms. You'll need a specialist meter or DSO.
Do it when the car's been sat a while - overnight at least - so you get the WORST reading.
If you don't have the tool, you need a thorough and 100% reliable battery test or a Plan B. Like buying a battery. Most everything costs more.
aholbro1
08-05-2021 05:02 AM
CClifton
03-19-2017 02:25 PM
CXJ
11-28-2015 11:41 PM
SouthernGypsy
09-23-2015 04:06 AM
pjanca
09-16-2015 08:07 PM
Quick Reply: wierd beepng.. "transmission fault" PLEASE HELP.!!
