Window doesn't go all the way down
Old Jan 26, 2012 | 12:39 AM
ChucksjagPatsmerc's Avatar
Default Window doesn't go all the way down
Ok, let me say first that it's my fault.
I had my garmin stuck on the drivers side window and pulled into a drive thru & without thinking hit the down on the window. Before I could stop it the Window was jammed against teh suction cup of the Garmin. I got it loose but now the window won't go down any further than that level.
Goes up and down fine, just not all th way down. I did this once before and within a few days it started working normally again. It's been over a week now and no change.
I have tried all of the suggested resets I could find in this forum except disconnecting the battery.
Please help.
2004 s-type 4.2 left side driver.
Old Jan 26, 2012 | 03:00 AM
JagV8's Avatar
Battery disconnect will likely do it. I suppose it's just the module that actually needs to lose power so maybe there's a fuse you could pull instead.
I expect a dealer could reset it but probably costs.
Old Jan 26, 2012 | 10:20 AM
Thank you I'll give it a try. I've been a little gun shy about it because of my wife's Mercedes, A lot of problems are linked to disconecting the battery outside of a dealership unless you have the right gear.
On that front, is there anything else that needs to be reset besides the windows after a battery disconect?
Old Jan 26, 2012 | 11:45 AM
Just the clock and maybe radio presets I think.
Old Feb 1, 2012 | 02:58 PM
Haven't tried it yet, but strongly suspect it will work.
Thank you for the info and support
Old Feb 1, 2012 | 03:05 PM
Michael Star's Avatar
**Hopefully** You didn't break the plastic holders, as they are a common fail point.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
rentzoo
Nov 10, 2015 04:56 PM
MHF25
Sep 13, 2015 05:24 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
