Windshield wiper/washer mystery
Old May 15, 2018 | 09:56 PM
Rex's Avatar
Rex
Default Windshield wiper/washer mystery
Daughter now driving the car. She called me a week or so ago, wipers not working. Called later, all was fine. Went out for dinner today, wipers, washer not working. All fuses good. Where do I start looking? Seems to be an issue with wiring to the switches?
Old May 16, 2018 | 01:18 AM
JagV8's Avatar
At the least the electrical guide shows relays etc JagRepair.com - Jaguar Repair Information Resource
Old May 16, 2018 | 09:29 AM
clubairth1's Avatar
Community Influencer
Maybe the stalk on the column?
Old May 16, 2018 | 01:34 PM
kr98664's Avatar
There are some relays that control the wipers, but I don’t see how a problem there could take out the washer pump, too.
Note in that diagram (section 13.1) you will see two pumps. The windshield washer pump is obvious, that sprays the windshield. The second is a little confusing. It’s called the power wash pump and is for the optional headlight washers. Don’t let that confuse you when troubleshooting.
The next time the car acts up, try to operate the front passenger window or adjust the right side exterior mirror. Both get their power via Switched System Power Relay #2. See figure 01.3. If that relay were to act up, you’d lose the wipers, washers, front passenger window, and the right mirror. Since the mirrors are already set, you’re not going to notice if one is intermittently dead. Same with the window, as you’re not likely to open it in the rain.
Old May 16, 2018 | 02:38 PM
Rex's Avatar
Rex
Mirrors and windows work. Washer and wipers are on different relays so simultaneous fault unlikely. Have wiggled the stalk a lot, no effect. Will have to start taking things apart.
Old May 30, 2018 | 01:46 PM
Rex's Avatar
Rex
The switch had failed. $300 from Jaguar.
Old May 31, 2018 | 09:12 AM
clubairth1's Avatar
Do you mean you replaced the turn signal stalk?
They are about $250 new from Jaguar so I think that's what was replaced?
Old Jun 1, 2018 | 10:15 AM
Rex's Avatar
Rex
Yes, the stalk is on order.
Dgoose78
Nov 22, 2014 09:54 AM
jimlombardi
May 31, 2014 09:58 AM
Len Apcar
Oct 9, 2013 09:12 AM
AliasIsApac
Dec 21, 2012 02:58 PM
gagets
Jun 8, 2011 05:48 PM
