Windshield wipers won't work on high!
Old May 12, 2012 | 12:44 PM
Parnevik's Avatar
Default Windshield wipers won't work on high!
Hi, I have a 2003 S-Type R and the wind shield wipers work fine on all settings except for high. I suspect it is some type of relay problem but need some help in even attempting where to start. Thank you very much!
Old May 12, 2012 | 05:21 PM
bfsgross's Avatar
The wiper wand may be faulty.
Old May 12, 2012 | 08:55 PM
FloridaJag's Avatar
It may be your wiper motor. Based on my experience, most problems with wipers can be traced to the wiper motor. Changing the wiper motor takes about an hour and a reman unit from NAPA runs about $55.00.
Old May 12, 2012 | 11:19 PM
03Xtype's Avatar
If the motor was going bad I would think he would have more issues with it than just the high setting.
Old May 13, 2012 | 07:47 AM
bfsgross's Avatar
ditto.
Old May 22, 2012 | 03:06 PM
Parnevik's Avatar
Default Fixed it!
So I took a chance and ordered a new fuse and it worked! Very bizarre as it would work on all settings except high, but for $10.00, was worth the risk! Thank you to all who responded.
Old Aug 20, 2017 | 07:39 PM
kemp neal's Avatar
Reviving this old post. Mine is doing the same thing. Is it a fuse or relay and which fuse was it.
Old Aug 20, 2017 | 11:53 PM
kr98664's Avatar
Wiring diagrams here:
JagRepair.com - Jaguar Repair Information Resource
Scroll to section 13.1.
Note relay R15 in the front power distribution box. If R15 has failed, it can't send power to the motor's high speed windings. Try swapping R15 and R18 (washer) and see if high speed works again.
Old Aug 21, 2017 | 07:14 PM
kemp neal's Avatar
Thanks for your reply. I should have clarified that the problem is with my 2005 not my 2003. In looking at the fuse boxes it seems they are different. My problem is that the wipers will not operate in high speed. The speed is the same in positions I as it is in position II. The wipers work in both positions, but at the same speed.
Old Aug 21, 2017 | 10:04 PM
kr98664's Avatar
Okay, follow that same link in post #8. Open the wiring diagram for your year. It's still section 13.1 for all years. The relay numbers may be different but you should find one for the high/low selection.
BrentGardner
29
Dec 16, 2024 12:13 AM
CaneCounsel007
Dec 29, 2015 08:35 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Lubrication
Sep 4, 2015 04:22 AM
johanasu
Sep 3, 2015 12:39 PM
