Wing mirror problem
The right (passenger) side door mirror will not hold its place. I am constantly moving it back into alignment. All it takes is to open or shut that door. Is this a memory function fault?
Is it when you open and shut the door or when you lock/unlock it with the fob, I'm sure you are able to set different memory positions for each fob/key. Would a battery disconnect clear the stored memory? To reset it?
