Wow! Hotness
Old Aug 12, 2008 | 02:40 PM
Default RE: Wow! Hotness
Could be the parking brake needing reset.
Old Aug 12, 2008 | 02:47 PM
Dennis's Avatar
ud
Something ain't right..
Old Aug 14, 2008 | 08:26 AM
12RM's Avatar
Try this -
Electronic Park Brake (EPB) –
Re-Calibration Procedure
2003 MY-ON
S-TYPE
M44998-ON
Issue:
On some 2003 MY-on S-TYPE vehicles, a customer may report a concern of premature
parking brake pad wear or the brakes binding. This condition can result if the electronic
park brake (EPB) system is not re-calibrated after the removal of the rear brake calipers
to replace the brake pads.
Action:
Should a customer express concern regarding the above, refer to the calibration
procedure detailed in this bulletin.
1. Reset the EPB module:
a. Switch off the ignition.
b. Disconnect the battery for 30 seconds. For additional information, refer to STYPE
Workshop Manual Section 414-01.
c. Reconnect the battery.
2. Start the engine.
3. Firmly apply and release the footbrake five times.
4. Confirm that the message ‘NOT CALIBRATED’ or ‘APPLY FOOT AND PARK
BRAKE’ is displayed on the instrument cluster message center. This indicates that
the parking brake is in calibration mode.
5. Lightly press the footbrake pedal.
6. Apply the parking brake by using the EPB switch.
7. Release the parking brake.
8. Release the footbrake.
9. Confirm that the brake warning lamp is no longer illuminated on the instrument
pack and that the ‘NOT CALIBRATED’ message is no longer displayed in the
message center.
10. Apply and release the EPB five times to ensure no error is present.
Old Aug 14, 2008 | 08:35 PM
snooktarpon's Avatar
Do you need to re-calibrate after every brake pad replacement?
Old Aug 15, 2008 | 01:39 AM
12RM's Avatar
ORIGINAL: snooktarpon
I would. I am not aware of the correct procedure though. Better safe than sorry, heard too many stories about burned out discs, pads and even bearings.
Old Aug 25, 2008 | 03:52 PM
MidGaSTR's Avatar
Your answer is 4 posts up....
Old Aug 26, 2008 | 07:55 PM
jag_genius's Avatar
sometimes it has to be done thru ids reprogramming of the EPB module.. simple calibration does not work all the time
Old Aug 27, 2008 | 07:24 PM
jag_genius's Avatar
then you have to go to the dealer..
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
rgp
Oct 1, 2015 02:55 AM
dmatthewman
Sep 30, 2015 10:10 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
