X-Pipe
Old May 11, 2009 | 04:38 PM
jaguarevan's Avatar
Default X-Pipe
I replaced the resonator with an x-pipe, I already have high-flow mufflers. I will say this, it is louder, quite a bit, but it is smoothing out the more I drive as it was quite poppy at first which you can hear some in the video. The power pick-up didnt appear to be much ( maybe a couple hp) on top of what the new mufflers may have picked up from stock,this was done last year, no dyno then, sorry. But if you are looking for ideas to get a little more sound out of your car I would reccommend. I would be interested to see what sound difference this would make with the stock or more restrictive mufflers. No drone inside the car while crusing (especially on interstate), but its definately noticable at acceleration.
Old May 12, 2009 | 02:32 PM
Laird Donnachaidh's Avatar
Default Mufflers?
Who's High-Flows are you running?
Old May 12, 2009 | 04:30 PM
Racerwrx66's Avatar
Uh oh, I have to I have to get a Jag now!
Old May 13, 2009 | 12:47 AM
v8stype's Avatar
jaguarevan your car sounds good nice to see someone post pics/videos.Im getting a 04 s-type r in 3-4 months and gonna run a similar exhaust set-up except no cats.
Old May 13, 2009 | 09:58 AM
jaguarevan's Avatar
They are magnaflow mufflers that I purchased that are center to offset (see the older pic below without x-pipe) and you can see right through them and then I purchased the tips I wanted and then we welded it up. Had to modify the hangers but not that bad. Both times the initial sound wasnt the best but shortly thereafter it really smoothed out.
Old Feb 7, 2010 | 09:16 AM
390HPTypeR's Avatar
What size tips are those??? They look like they are 4" and they look great...
Old Jun 1, 2010 | 02:31 PM
Michal's Avatar
Is there any or more drone comparing to when you only had read mufflers with resonator on?
Old Jun 1, 2010 | 02:41 PM
Riski's Avatar
Your exhaust is almost IDENTICAL to what I did to my STR
http://www.youtube.com/watch?v=XbtINxEVtlQ
Old Jun 1, 2010 | 05:44 PM
RobGardnerBlack's Avatar
Jaguarevan;
Nice set-up and fabrication - I noticed both you and Riski have mentioned the note smoothing out more as time goes by. Why is this?
I used Riski's set-up but stopped short of the resonator delete and I too have noticed the note change over time, not much but a change never the less.
Old Jun 1, 2010 | 08:49 PM
Riski's Avatar
The mufflers need time to go through its cycle.....that is why they change a bit....Magnaflows are known for this more than others...
2010 Kyanite XFR
May 16, 2017 10:02 AM
SanDiegoMac
Feb 21, 2017 08:03 PM
Daim
Nov 28, 2016 09:28 AM
multistrada74
Jul 11, 2015 05:45 PM
VIAPA2
Jun 19, 2014 12:03 PM
