Xenon Headlight out - What to check? / Next steps?
Old Jul 6, 2009 | 09:15 PM
T.C.'s Avatar
Try swapping the lights themselves between right and left sides. IF the left is still out after that then you have a bad fuse, ballast, wiring, or relay. IF it lights up then you need new bulbs.
I suggest E-bay, you can get some D2S bulbs is just about any color for cheap (~50 dollars)
Old Jul 23, 2009 | 04:40 PM
carate's Avatar
Default Wiring trick
I used the DS2 bulbs ($58ish for 2 in canada).
Yes you have to remove the bumper and headlight unit to gain access to the rear.
NOTE _ The new bulb will not mount properly if the electrical connector is not attached.
Do both units while you have the bumper off!!
Old Oct 8, 2009 | 12:46 PM
Caesar's Avatar
HI @ all!
Do I need D2S Bulps for every S-Type R? Also for euopean ones?
Why are there so much price differences? Just because of the brands or are there some facts I have to look at?
Are 6000K ok? or do I need an other Kelvin bulb?
Thanks a lot!
Greetz
Old Oct 8, 2009 | 01:53 PM
StrateLoss's Avatar
check the fuse first, if blown replace it.
if the fuse is good check the actual connector, maybe they seperated,
if the connector is fine then check and see if the ballast work. youll need someone to turn on the lights while you have your ears near the ballast.
if it hums, it works. if it doesnt hum, theres your culprit.
if it doesnt hum then its either bad, or not getting power. you can check and see if its getting power with a voltometer READ THIS > do NOT test ANY wiring coming from the ballast. ONLY check wires that LEAD to the ballast.
if it gives voltage then the ballast is bad and youll need replacement.
you can swap the bulbs as mentioned earlier to see if the bulb is bad,
if bulbs are swapped and still no light, it may be the ignitor which houses the bulb. youll need a replacement as well.
original phillips d2s 85122+ bulbs can be purchased on ebay for around $80 shipped. if you have a hardtime finding a pair, or not sure which seller to buy from i can give you the ebay id's of people ive had great experiances with.
Old Oct 8, 2009 | 02:49 PM
Brutal's Avatar
since I rebuild broken headlight assemblies on the side. I can tell you that the number 1 thing that goes out in them is usually not the bulb, (burner), but the ballast. And yes to confirm before you start buying parts, swap the burners out side to side. I have yet to ever see a blown fuse for one, but what the hell you can and should check the easiest thing first....
Old Oct 8, 2009 | 03:24 PM
Caesar's Avatar
HI,
thaks a lot for the tips!
I'll check the ballast tomorrow! How can I check the connectors?
To swap the left bulp to the right side and the other way round is a good idea, but therefor I need to know if it is possible without takeing the bumper off?
I already checked the fuses, but they seemed to be ok! If they would have been broken, I should see a crack in the metal string...right?
Thanks for your help!
Paul
Old Oct 8, 2009 | 04:14 PM
Brutal's Avatar
Originally Posted by caesar
hi,
I'll check the ballast tomorrow! How can i check the connectors?
To swap the left bulp to the right side and the other way round is a good idea, but therefor i need to know if it is possible without takeing the bumper off?
I already checked the fuses, but they seemed to be ok! If they would have been broken, i should see a crack in the metal string...right?
Paul
nope pull the bumper
Old Oct 9, 2009 | 01:18 AM
Teck4Jag's Avatar
if interested i have ballast,and burners both new and oem
Old Oct 10, 2009 | 05:05 AM
Caesar's Avatar
HI,
I checked if there is any humming sound! And there is! So I think it can't be the ballast!
So it must be the bulb...right?
So I have to take off the bumper?
Old Oct 10, 2009 | 11:29 PM
StrateLoss's Avatar
as long as the humming sound is coming from the side that is NOT working , then its most likely the bulb.
once your bumper is removed swap the bulbs left to right and confirm that its the bulb. then replace accordingly.
Old Oct 11, 2009 | 10:29 AM
badmojo's Avatar
Pulling the bumper cover is not nearly as hard as it sounds. Max time is about 20 min. if you leave the bottom splash cover attached and just let it lay down in front of the car. Then you open up all the access that you will need to easily swap any components. The screws behind the fender liner (1 per side) are the toughest but their not bad if you turn the front wheels as needed. Once it's done you'll wonder why you didn't just do in the first place.
Old Oct 12, 2009 | 11:48 AM
Caesar's Avatar
Hi,
the only thing, which is a bit strange, is, that sometimes, when I turn the light on, the one which usually doesn't work, flares for a very short time and then it is off again.. is this possible when the bulb is bad?
Greetz
Paul
Old Oct 12, 2009 | 02:16 PM
StrateLoss's Avatar
Paul, you should just swap bulbs already.
Old Oct 12, 2009 | 08:41 PM
badmojo's Avatar
Mine would come on a dim blue then blink or flutter then go out. It was the bulbs.
Old Oct 13, 2009 | 01:52 AM
Caesar's Avatar
HI,
ok, sounds good! I'll swap them, but I don't want to take off the bumper twice! I'll do it, when I get the bulbs!
Old Jan 29, 2017 | 07:04 PM
Lburdette0807's Avatar
Default Fuse
mine actually blew both fuses at the same time after hitting a cattle grate. Replaced the fuses then the passenger side kept blowing. Still haven't figure that one out, gotta be a short somewhere.
Old Jan 30, 2017 | 02:04 AM
JagV8's Avatar
Wow, what an old thread!
dsnyder586
Dec 29, 2024 07:39 PM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
laserguy
Sep 3, 2015 02:02 PM
