yet another rotor thread...
Old Oct 12, 2010 | 07:43 PM
twastheglow's Avatar
Default yet another rotor thread...
Hey guys, I searched a bunch already and couldn't find a specific answer to my question, so I apologize if this is redundant...
I have a 2006 S-Type 3.0 and I'm looking to replace the front and rear rotors. I've been searching online and seem to keep finding different sized rotors listed for the front of this car (300mm/326mm). Also, the rears seem to be listing as 326mm too. Is that correct? I'm debating between Centric and Zimmerman rotors. I guess my question is what size are the fronts and rears? I don't want to order the wrong size. Thanks.
Mike
Old Oct 13, 2010 | 05:45 AM
JOsworth's Avatar
Best bet is to contact the retailer you are considering using and give them your VIN. Both sizes are considered correct. The larger front rotors are a "sport" package spec. Also, Jaguar made some brake changes to all models in 2006 so in your case VIN is even more important. If the retailer you are using doesn't ask or want your VIN, run away real fast!
Old Oct 13, 2010 | 06:01 AM
JagV8's Avatar
+1 on that - there are several different standard sizes for the various years, models & options and only the VIN allows the right ones to be found
Or, if you TRUST those who owned the car before you to have fitted the correct rotors, measure them.
Old Oct 13, 2010 | 06:14 AM
Thanks for the info/tips guys.
Those are actually both great points. In the mean time I went out and measured the fronts and rears and they both come in 12.8" (326mm).
I'm quite confident that the rotors are actually original as the car has pretty low mileage. I had them turned but to no avail so I'm just going to replace them.
I think I'm going to go with a set of the Centric rotors.
Old Oct 13, 2010 | 06:17 AM
^ I see this forum is a V-Bulletin forum but I can't seem to find an edit post button like other forums I'm on.
I wanted to add that I just should have measured them in the first place. LOL
Old Oct 13, 2010 | 06:27 AM
JagV8's Avatar
The IS an edit button - but perhaps not until you've been a member for a while.
I'm surprised they're the same size.
Old Oct 13, 2010 | 06:33 AM
I guess when you're a noob your posts are set in stone. lol
I was surprised too actually. But when I look up the part numbers they arer indeed 326mm.
Front
Rear
Old Oct 13, 2010 | 06:36 AM
^ And those are Centric part numbers/diagrams...but after measuring and find them both to be 12.8", I guess it's correct.
Old Oct 13, 2010 | 06:59 AM
JagV8's Avatar
Yeah, noobs are different in case of spam, but you're doing fine - welcome to the forum!
Oh, now's a good time to put your car details where they show (signature or wherever) on your posts.
Old Oct 13, 2010 | 07:10 AM
hahaha Thanks.
Will do!
kthrash
Feb 25, 2019 10:20 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
