ZF Transmission Question
Old Nov 15, 2013 | 08:35 PM
55jag05's Avatar
Default ZF Transmission Question
Sorry if this has been discussed but I tried searching before starting a thread but couldn't find anything.
I'm still in the learning process. Have car less than 1 month.
Here's the question: Normally, the tranny shifts smoothly but sometimes when making a turn after stopping, it will stay in 1st gear too long and rev up very high before finally shifting to 2nd. This happens even with very light throttle pressure.
Is this something in the design or is there a malfunction.
Old Nov 15, 2013 | 09:37 PM
Prestige Autowerke's Avatar
Sounds like a little bit of transmission slip. Replace the fluid and filter, as your filter may be plugged.
Old Nov 15, 2013 | 10:17 PM
Bad Cattitude's Avatar
How many miles on the car?
Old Nov 16, 2013 | 09:09 AM
55jag05's Avatar
Car has 90K and fluid was changed prior to purchase as part of the deal.
Old Nov 16, 2013 | 09:25 AM
JagV8's Avatar
Hard to know if they filled it properly, then
It's a critical process, as HOW TOs explain.
Old Nov 16, 2013 | 10:26 AM
As stated above I would verify the level and if the filter was changed. A fluid change without a filter is useless.
Old Nov 16, 2013 | 11:16 AM
Also ask if the TCM was reflashed.
Old Nov 16, 2013 | 01:17 PM
55jag05's Avatar
Thanks for the tips.
Old Nov 16, 2013 | 06:46 PM
motorcarman's Avatar
The question might be??????????????????????
Was the CORRECT fluid used????????????????
bob gauff
Old Nov 16, 2013 | 07:48 PM
FreshJag's Avatar
Mine does the same thing and it usually shifts somewhat harsh in 1st to 2nd. Keep us posted and good luck on finding out the issue.
Old Nov 17, 2013 | 07:25 AM
clubairth1's Avatar
Community Influencer
As always take a look at the "Lurch" to see if anything matches what your car is doing.
The guy is off the deep end but he did buy it new which was his first mistake!!
Jaguar S-Type Ownership Experience - The ZF LURCH Fault
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
ahunt4
Sep 14, 2015 08:17 PM
AtholC
Sep 9, 2015 09:07 PM
