Dunfounded
Old 05-21-2017, 03:57 PM
Doug Gordon's Avatar
Default Dunfounded
Code C1637 any ideas what or how to correct this? Has something to do with the ABS system. 2002 XK8 4.0 And do I need a new module? Help me please I'm totally lost on this one!
Old 05-21-2017, 04:09 PM
RDMinor's Avatar
Are you positive it's a C1637 and not a P1637?
Old 05-21-2017, 04:51 PM
yes. I even double checked . just took her for a drive showing engine light , dash says track not available and ASC not available along with the Abs light. I'm assuming that the Asc is the cruise control because that's not working .
Old 05-21-2017, 04:54 PM
jimbov8's Avatar
Start by ensuring the battery is fully charged then try again.
Old 05-21-2017, 04:59 PM
just put in a brand new battery. 2 week ago the best Bosch platinum series!
Old 05-21-2017, 05:55 PM
GGG is online now
Received 16,800 Likes on 12,169 Posts
According to the Jaguar DTC Summaries, C1637 is not an assigned error code for the 2002MY XK8.
Old 05-21-2017, 06:27 PM
thanks Graham , I just checked with the mechanic who owns the snap on scaner and he said it was a c1637. He headed to his garage to look it up .he told me thats what it was showing. He'll call me back and I'll let you know.
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
What code reader are you using to get this C code?
Old 05-21-2017, 06:29 PM
its a snap -on
Old 05-21-2017, 07:01 PM
all right here the deal ,it was showing a P1637 before he cleared the engine codes ,an then going thru the hole system, he found code C1137 which pretty much says the same thing . ( no can signal from ABS module) what ever that means. I can only guess that my Abs module has taken a crap! Now the question is, where the best place to get a repop?
Old 05-21-2017, 07:06 PM
your right , had a p1637 cleared it out then it was showing a new code C1137. Pretty much the same thing! ABS Module is shot. Now where's the best place to get a repop?
Old 05-21-2017, 08:45 PM
StuG's Avatar
Hi Doug,
It's probably just dodgy solder joints in the ABS module. You can get it rebuilt in a couple of weeks or less. Way cheaper than trying to source a new one.
1998-2003 Jaguar XJ8 XKR XK8 ABS Module Repair Rebuild Sevice | eBay
Stu
Old 05-21-2017, 08:55 PM
Why are there 2 different posts on this same subject?????????????????????????????????????
bob
Old 05-22-2017, 03:56 AM
Originally Posted by StuG
Hi Doug,
1998-2003 Jaguar XJ8 XKR XK8 ABS Module Repair Rebuild Sevice eBay
Stu
allready solder them , thanks Stu
Old 05-22-2017, 03:58 AM
bob
sorry Bob I Think it's my fault
