Help me find a break in the fuel pump relay circuit
Old May 6, 2026 | 03:40 PM
Ice7Burg44VDP's Avatar
Default Help me find a break in the fuel pump relay circuit
I just had a new fuel pump and flange installed on my car. Now the shop is saying there is a break in the fuel pump relay circuit, which WAS NOT THERE BEFORE. Does anyone know where on a 2001 jaguar xj 308 a break in the fuel pump relay circuit is most likely to occur. This wasn't an issue before I brought it into there shop. Could it be as simple as a fuse or relay, or could they have damaged it during the repair process, only to add it to my bill. What do yall think??
Old Yesterday | 05:03 AM
eliotb's Avatar
I'm not a real expert on these matters but this discussion at the bottom of today's message might be helpful: https://www.jaguarforums.com/forum/x...-relay-295856/
Old Yesterday | 11:47 AM
Parker 7's Avatar
Notice how the fuse is after the relay
Notice the secret fuse in the left heelboard fuse box # 10
This fuse may have to have the ignition positive # 2 close to power the fuse
This relay can be seen on page 39 and 41 as the 2 circle double hash electrical point
jagrepair.com/images/AutoRepairPhotos/jagxj2001.pdf
Your fuel pump control is Y electrical point
Old Yesterday | 11:51 AM
Jhartz's Avatar
I would suspect that the break is along the line that runs from the fuel tank to fuse and relay box: said another way, the shop needs to redo their work (at their expense).
Old Yesterday | 12:12 PM
Parker 7's Avatar
Somewhere along the way something not correct on above post , will have to revisit
Old Yesterday | 12:22 PM
Jhartz's Avatar
Huh? What are you saying, Parker? I think the shop broke an electrical line to the fuel pump on either removing the tank and fuel pump or on reinstalling same . . . it is possible that they also blew the relay and/or fuse in the process. The shop needs to check their work -- not impossible that something other than the fuel pump going bad, now fixed, surfaced after the repair, but doubtful: just not a fan of coincidence (maybe cuz I have fat fingers with arthritis, prone to errors). They broke a line and need to run continuity checks across the circuit, ne? Or bridge it.
Old Yesterday | 01:07 PM
Thanks! This was my reaction as well when they tried to add to my invoice a problem I NEVER had before going to there shop. Too money hungry and greedy to ADMIT there fault and double check or repair their faulty wiring.
Old Yesterday | 01:08 PM
Hopefully, it is just a blown fuse or relay that needs to be replaced.
Old Today | 06:38 PM
Parker 7's Avatar
Will have to retrace my thoughts on the dialysis chair in the morning , lacking internet now
BradsCat
Jan 13, 2021 07:17 AM
cooke
Mar 28, 2012 05:41 AM
daboss085
Mar 7, 2012 02:36 PM
Grssa
Jan 23, 2012 11:07 PM
Mike Trusky
Oct 21, 2011 08:46 AM
