US Lower Atlantic NC SC FL GA
I/C renew with Bosch
Old Jul 28, 2019 | 10:52 AM
James Teddy Gillis's Avatar
Default I/C renew with Bosch
After fabricating the original pump bracket and installing MBenz AMG 63 connector the job was plug-n-play. Finished the job with cooler t-stat and vacuum filled with straight MB pink coolant. Results... noticeable city driving more torque with less throttle. Downshifts earlier. P.S. dont forget to remove battery gound and short to positive for hard reset. Turn on let sit for a min (throttle relearn) then start and idle till fans operate. No ac on, accs off. Drive normal and key cycle at least once before letting her loose
Reinstalled old bracket aftet rimmed and bent on bench with new pump and hose clamp fitting. Sorry poor pick.
Bosch pump from CLS 63 or any AMG 63. Dont forget to order connector.
Pump fitted
Notice hose clamp. No adjustments to hoses. Reinstall original rubber insulator to pump.
And finish the job with cooler t-stat.
Old Oct 27, 2019 | 03:43 PM
ednedwards's Avatar
What car was this installed on?
Old Oct 27, 2019 | 05:42 PM
2004 XJR. Might be similar to your Stype
Old Oct 28, 2019 | 08:03 AM
ednedwards's Avatar
Same engine as my 03 s type r. Does the pump have a higher flow rate and how hard was it to modify the bracket?
Old Oct 28, 2019 | 12:23 PM
Of course it does hence the upgrade. Easy modify but your bracket may be different multiple post about pump performance
Red1bw
May 3, 2026 03:31 PM
Bigg Will
Sep 11, 2023 02:19 AM
Spikepaga
Apr 23, 2019 06:20 PM
JaguarVDP
Dec 1, 2018 09:33 AM
EZDriver
Aug 13, 2014 09:14 AM
