US Midwest IL, IN, IA, MI, MN, MO, OH, WI
Tibbe Key cutting in SW Ohio
Old Oct 15, 2014 | 02:51 PM
hafren's Avatar
Default Tibbe Key cutting in SW Ohio
Does anyone know of a locksmith or dealer that can cut Tibbe keys? I am in Dayton OH dos would appreciate any help from forum members. Thanks.
Old Jan 9, 2016 | 07:28 AM
Mad_Russian's Avatar
I am also in Dayton, trying to figure out the same thing. Apparently Ford cars used the same key in the 80s and 90s, there is a chance on of them might be able to do that. I'll call around today and see. Blanks are available on line for 10 dollars each.
Old Feb 17, 2016 | 05:50 PM
hafren's Avatar
Hi
I don't look at the regional forum much as there has been almost no response to posts; until yours!! Fyi I ended up buying a precut key see my post https://www.jaguarforums.com/forum/x...cement-134200/ I searched locksmiths Dayton/Columbus/Cinci without success and jag dealers in Dayton and only found the Cinci Jag dealer could help but they didn't have key cutting capabilities just ordered one from Jag USA. I can recommend he UK key & cutting source - price was reasonable and delivery pretty quick ~10 days
I didn't see, from your post, what vehicle you have so I'm not sure if you need to program the key to the vehicle PATS?
PM me of you want to continue the dialogue
Good Luck
Old Feb 17, 2016 | 05:57 PM
hafren, thank you for the reply. I have a 1993 xj6. I ordered key blanks on Amazon, 2 for 17$ and had Jaguar of Cincinnati cut them for $25 a piece. My car does not have a transponder (thank GOD), so the process went reasonably smooth. The new key also cured the no-start issue that I was experiencing with my original worn out key.
Old Feb 17, 2016 | 05:58 PM
hafren's Avatar
Just searched your "handle" and see you have an XJ40. I'm not sure if that uses a Tibbe 6 or 8 key? My XJ350 uses Tibbe 6 but the cutting and concept are the same just different blanks.
File Type: pdf
Old Feb 17, 2016 | 06:00 PM
hafren's Avatar
Great to hear you had success with Cinci Jaguar. I obviously got some bad info when I called them.
Old Feb 17, 2016 | 06:05 PM
Mine is definitely a Tibbe 8. I'm glad to see another Jag enthusiast in my neck of the woods.
dsnyder586
Dec 29, 2024 07:39 PM
philwarner
Oct 4, 2024 01:37 PM
peterg19
Feb 10, 2023 09:02 PM
jagent
Sep 12, 2015 09:10 AM
brgjag
US Midwest
Sep 4, 2015 11:24 AM
